Eli K's Avatar
complete rewire
Curious to see if anyone has tried to re-wire their 944 from scratch?
I'm inclined to try this on my 924S.
Being a dedicated race car, the amount of wiring would have to be fairly minimal.
Old 03-12-2006, 10:24 PM
Sounds like a cool idea. My friend recently wired up a 240sx that he had completely stripped down. He managed to clip out 15lbs worth of accessory wires. You might be able to do the same. I've also had a lot of electrical problems and was thinking about going over my wires as well. Good luck to you and I hope you succeed.
Old 03-12-2006, 11:01 PM
Eli K's Avatar
Thanks. I don't think I have a choice in the matter. The PO attempted the re-wire on his own which resulted in multicolored wires being strung all over the car.
Old 03-13-2006, 07:54 AM
Eli K's Avatar
Could anyone recommend a shop within a 100 mile radius of DC? Preferably a shop that's done this type of work before and if familiar with the wiring of these cars, etc.
Old 03-13-2006, 08:03 AM
I go to a shop called Pro-Imports, located in Rockville. They concentrate primarily on German and Japanese cars. Pretty nice people and they're performance oriented and they focus on keeping cars on the road for as long as possible. You can check them out at http://www.pro-imports.com/ I don't know how much rewiring they're capable of, but they managed to sort out a couple of my electrical problems (replaced a wire for my fuel pump relay and replaced my crank position sensors).
Old 03-13-2006, 09:23 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Rewire is a major undertaking to say the least! If it were not so involved I would replace every inch of wire. Porsche electronics are the worst IMHO! But as hot as these cars get it is amazing more wires don't melt so it does say a good thing for the harnesses but the corrosion factor has little to be admired.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 03-14-2006, 05:00 AM
I completely rewired a '77 924 once.
well...twice...
well, no, two and a half times.
It's not fun, but probably woulnd't have been too bad if I could have found the proper wiring harness in the first place.
Old 03-14-2006, 09:49 AM
Virginia Rocks!
VaSteve's Avatar
Eli, do what my brother said. Find a harness and start there. Maybe buy another parts car and take notes as you take it off the other car. You're only taking about the engine....not the lighting/stereo and what not. I don't see this as a tough job..only a little tedius maybe.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 03-14-2006, 10:07 AM
