Scan to the sensors...
I started having troubles with my car randomly not starting and diesel'ing during shut off around the same time that I replaced my air filter and sprayed the inside with carb/choke cleaner. Is it possible that something could have happened with this?
I checked all of the hoses and plugs and everything is hooked up. What do you think? Should I check my sensors as well? Can I simply unscrew the sensors and screw it back in tightly? Thanks everyone!
1985.5 944NA http://www.kevinswebsite.com/944/ Last edited by Kevin0323; 03-14-2006 at 10:41 AM.. |
