Accessing Alternator on 951
Hey all,
I'm working on installing a lighting upgrade and I'm wondering if it's possible to access the back of the alternator without removing the intake manifold on a 944 turbo. If it's absolutely impossible, I think my project will have to wait until summer. ![]() Thanks
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender |
Oops. I just realized that clark's garage doesn't even mention the intake manifold. Here I go. I hope it's not too difficult.
If you have small hands its ok............ the little bolts holding the air ducting cover can be a pain.......
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
The duct bolts weren't too bad to remove. I'm having so much trouble removing the tensioner bolt holding the A/C compressor. I don't know if I'm just a girly man or if it's because I'm trying to pull some torque while lying on my back, but this thing just doesn't want to loosen. Man, what I would give for a 3/8" breaker bar right now.
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender Last edited by swimmingly; 03-14-2006 at 03:25 PM.. |
Cars & Coffee Killer
I might have to do my alternator this year. Clark's garage says that I have to drain the cooling system. I'm not looking forward to it.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
legion, I don't know how I pulled it off, but I never touched the cooling system and managed to remove the alternator altogether and put it back in. It took some effort and a lot of time and patience, but I don't think removing that coolant hose is necessary.
That's encouraging. Thanks!
