Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Alignment questions
After doing some cleaning up, I came across the result sheet from a previous alignment (late 2004), and remembered that some of my results were out of spec.
Basically, the left rear camber is supposed to be -1.31 min. and .69 max, and mine measured at -1.48. On the other side, it was -2.48. Toe on the right rear is supposed to be -.05, and mine measured .26. The left side's toe was in-spec.
On the front, Caster is supposed to be min. 2.25 and max 3.00, and mine measured 1.87 left and 1.36 right.
The printout claims that any of these results could be caused by tire wear or by bent or worn suspension parts. If it was bent or worn suspension parts, does anyone know what I should be looking at?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-20-2006, 09:14 PM
Writer/Teacher
CJFusco's Avatar
bumparoo?
Old 03-21-2006, 08:52 PM
Eldorado's Avatar
dealing with numbers like the way you are, you'll probably need to wait for someone that has access to the equipment (read: someone like juvi)
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-21-2006, 11:40 PM
Back from Beyond
Caster - bushings, basically. Camber - upper strut mount. Toe - tie rods/tie rod ends. I'd also make sure to adjust front wheel bearings before an alignment because they affect how the wheel will sit. This is principally front end. I was told once not to bother with rear bushings because they're a PITA to R&R and the results are minimal.
Many folks won't touch the rear settings because they're scared of the car. Ask your favorite P-car shop who they use foir alignments.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 03-23-2006, 02:12 PM
Writer/Teacher
CJFusco's Avatar
Interesting, because since then I've:
Replaced most of the bushings and both sets of tie rods and ends. I bet this fixed most of the "problems."
Old 03-23-2006, 09:07 PM
