Greasy Member
many944s's Avatar
Random questions
Question 1: Anybody ever have the "fresh air" blower run as soon as the car is turned to the "on" position? I can run the fan switch through all of its positions, and it just wont turn off. It's as if the switch is always stuck on the "1" position?
Question 2: I just replaced the drivers side stub axle on a friends 84 44, when I removed the old one, I found that at some point someone left a broken CV bolt in the "Flange Shaft" on the transaxle. I ended up having to pull said piece to try to easy-out the broken off bolt. No luck, the bugger is truely stuck in there! Because of the bolt size, it of course is not possible to drill and over-tap the hole. Long story short, anyone know where to order this flange?
Thanks for any info.
Nick
55 Ford Fairlane
69 Triumph Spitfire MK III
74 VPJ Indy Car
82 DeLorean (lost in divorce)
83 944
85/1 944
87 924S (wrecked at Speedway)
95 Ford Mustang
Old 04-02-2006, 07:35 PM
Question 1 - I was thinking that an owners manual will solve my problem. My 86 is identical. Always blows. I'll keep you posted and let you know what the manual says.
Question 2 - good luck. Sorry no advice hear.
Frank
1986 944 N/A Automatic
1958 Buick
1954 Chevy
1929 Model A Roadster
2006 Triumph America
2006 VW GLI (gotta go to work)
Old 04-02-2006, 07:44 PM
My "fresh air" blower runs in all positions also.
86 Red 944(sold)
85.5 Red 944(sold)
Old 04-02-2006, 07:50 PM
Ornery Bastard
The blower on mine doesn't run at all positions. But if the car is moving at all you will get airflow through the vents.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-02-2006, 08:36 PM
SoCal Driver's Avatar
Two things happen to the air blower. The switch in the console overheats and warps sometimes locking the blower on and/or the balast resistor shorts out only leaving one speed. Note that the blower is always on at a low speed. This is to keep the fumies from the exhaust out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-02-2006, 09:20 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
When mine did that, it was the ballast resistor. Never seen the console overheat problem, but SoCal knows a lot more about these cars than I do.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-02-2006, 09:39 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
You had a Delorean, eh? This was the first car that ever caught my interest, when I was a kid...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 04-03-2006, 06:50 AM
Greasy Member
many944s's Avatar
Yea, it was a beautiful car, but a real pain in the @ss to work on! Granted it came factory with a buick V6, but it had hoses that ran all the way to the front of the car to the radiator not unlike a Lotus Europa. (The lotus is another headache all together, I restored a '74 for my dad many years back)
Anyway, I managed to keep the house, and the P cars, the ex got the DeLorean, most of the funiture, and all her credit cards paid off! Then to add insult to injury I talked to her brother about 2 years after the divorce and found that she parked it in a barn to die... 4 flat tires, pigeon crap, coons, mice in the electricals.... (sigh....)
Old 04-03-2006, 07:04 AM
Nick,
On the other part, try these places....
Brims (Ohio) 800-221-3874
Oklahoma Foreign 800-462-2446
Fresno Silver star 559-268-7300
All import auto 817-831-6316
Not sure if they will have anything or not, but give them a try. Is there enough room to drill the old bolt out and replace the threads with a helicoil or a threaded insert? I think I would try that first.
Tom
Old 04-03-2006, 08:44 AM
