winter-hater club member
nynor's Avatar
O2 sensor location
ok, i am tired of looking through the PET and the workshop manual for this. i even tried clarks-garage. i know i can just trace the wires back...
where does the O2 sensor on my car live?
TIA
p.s.: and any hints on how to get to it and get it out are appreciated.
"COOL PRIUS!" - Nobody Ever
Old 05-08-2006, 09:32 AM
Circular Big Three pin plug Center of Firwall in clip (about thumb size). Pull apart (Un-connect) go to Sensor in the Exhaust pipe Before CAT after the 4-1 pipe. You need to jack car to reach. Easy pull out with a large open ended Wrech. Screws out like light bulb. Only wire going to Exhaust.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 05-08-2006, 09:57 AM
nynor's Avatar
i have all this extra piping between the 4-1 pipe and the cat, such as a cross over pipe and turbo....
Old 05-08-2006, 10:04 AM
Should Look simlar to this. Your turbo will have extra pipe after 4-1. I believe on the Turbo the Plug should still be near it.
Old 05-08-2006, 10:21 AM
nynor's Avatar
looks completely different.
Old 05-08-2006, 10:27 AM
Eldorado's Avatar
then I dont think it's stock, and I'd suggest following wires..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-08-2006, 10:50 AM
nynor's Avatar
bollocks...
Old 05-08-2006, 11:07 AM
Send a message via AIM to TheCooler
Its on your exhaust before your Cat.
I suggest a wrench to get it out.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-08-2006, 11:15 AM
nynor's Avatar
yep, stock, but still looks nothing like the picture posted. O2 sensor lives on the drivers side of the cross over pipe, way up against the turbo.
to my untrained eye, the old sensor looks pretty bad.
yep, a 7/8" wrench works like a champ.
Old 05-08-2006, 01:11 PM
