Virginia Rocks!
VaSteve's Avatar
Restart after engine out?
I'm still a couple of days from getting this running again, but I'll forget to ask before it's too late.
When reinstalling the engine what is the proper starting procedure?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-08-2006, 10:31 AM
Cars & Coffee Killer
legion's Avatar
1) Position friend with fire extuinguisher pointed at open hood.
2) Turn key.
No idea. I'd think you'd want to leave the key in the accessory position for a minute to load the fuel rail with gas.
5 liters of VVT fury now
-Chris
Old 05-08-2006, 10:36 AM
Eldorado's Avatar
2) Turn key.
LOL
that needs to go on clarks......
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-08-2006, 10:53 AM
Back from Beyond
For sure I'd disconnect the coil wire and crank it till I had really good oil pressure.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 05-08-2006, 11:01 AM
Send a message via AIM to TheCooler
Isnt it illegal to put older engines in newer cars?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-08-2006, 11:18 AM
Eldorado's Avatar
umm.. is that a serious question?
I dont know why it would be illegal...
Kyle
Old 05-08-2006, 11:41 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You crack me up Legion.....
Here is what I would do.
1. Disconnect the reference sensor ...this shuts off ignition and fuel injectors (another stolen tip from SoCal)
2. Prime the oil pump by pouring oil down the center hole of oil filter
3. Pull spark plugs and put small amount of oil in each cylinder
4. Crank engine over until you see oil pressure
5. Undo what you just did and after it starts grab yellow tool from tool storage.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-08-2006, 11:43 AM
Custom User Title
Dave L's Avatar
Polution controls. I dont think taking a 84 engine and putting it in an 86 is a problem as the engine is pretty much the same but you couldnt take an '80's 5L mustang engine and drop it in a Focus. Laws vary depending on where you are.
Old 05-08-2006, 11:56 AM
ae1969's Avatar
Send a message via ICQ to ae1969
I just pull the dme relay and prime the oil pump........
Crank ....... crank and crank......
It can take quite a while before you see oil pressure registering...... adding oil like Razor mentioned #2 definitely helps....
5-10 second bursts for me usually does it.
Once you have oil pressure......... plug the dme relay back in.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-08-2006, 11:58 AM
If the Valve cover is off, pouring a little Engine oil on the lifters and cam can easy friction at bit before the oil gets flowing.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 05-08-2006, 12:16 PM
SoCal Driver's Avatar
Engine had sat for almost four years. Pulled the plugs and the coil wire. Cranked for less than 20 seconds to get three bars of oil pressure.
Was easier to pull the coil to dist wire than to pull the connector on the sensor or the DME relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 05-08-2006, 03:42 PM
