Virginia Rocks!
VaSteve's Avatar
Need a little help with wiring (should be easy)
OK two softballs, guys. Thanks.
Ok, I'm almost at the point where I can start this thing (engine has been removed and replaced with an older block). Anyhow, I'm running the last of the wiring and found that I need to hook up the main ground. There's one in the battery box, but where on the engine does this go? Where the other grounds are (near the bell housing??)
Also, how many wires are supposed to go to the starter? I hooked up a small ware to the solenoid, and a bigger wire that appears that it belonged with it to the other post. I realize that this is always supposed to be hot, so I need to jack it up and run the final one from the battery which I'd forgotten. What is the other big wire or (not the solenoid?)
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-14-2006, 07:33 PM
ae1969's Avatar
Send a message via ICQ to ae1969
- the ground in the battery box bolts up to a bolt in that area...... up against the firewall.......... you should see grounds bolting up on the other side of that same bolt on the the other side of the firewall....l......
- 2 big wires and 1 little wire
1 little (for solenoid) + 1 big from alternator ........ 1 big from battery
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-14-2006, 08:01 PM
Virginia Rocks!
VaSteve's Avatar
Really? My negative wire is like a "Y" with a longer side. One part goes to the firwall obviously, the other is long enough to reach the back of the motor, but I can't recall where it goes.
Gotcha on the starter, thanks
Old 05-14-2006, 08:05 PM
SoCal Driver's Avatar
Goes on the back of the engine on the battery side. Depending on the year (and the month of the year is some cases) the ground cable can go directly to the back of the engine with a leg going to the fire wall. Or to the fire wall with a seperate strap going from the fire wall to the back of the engine.
Best to make sure the engine is grounded to the chassis otherwise all the cranking amps goes through the DME. Tends to burn them out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-14-2006, 10:13 PM
Virginia Rocks!
VaSteve's Avatar
Maybe I'm mixed up since the new motor is older. I'll look it over closer tomorrow.
Old 05-14-2006, 10:47 PM
Same place on the early blocks as well as the later.
Old 05-14-2006, 11:04 PM
Zero10's Avatar
Send a message via ICQ to Zero10
On the early bodies, the engine is grounded to a post on the firewall. On later cars, it is grounded to the battery. In both cases, the bolt for the ground wire on the block is located near the elbow for the heater valve, but on the block instead of on the head.
For the starter, you normally have 1 small wire for the solenoid, 1 large wire from the battery, 1 medium-large wire from the alternator.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 05-16-2006, 06:26 AM
Virginia Rocks!
VaSteve's Avatar
Yeah, what a pain, I figure this out only after every thing else was hooked up. I can't count how many times I've had to remove the bracked for the speed and reference sensors. LOL.
JOb was easy, just had to avoid dropping the bold into the flywheel inspection hole. LOL.
What crazy engineer figured out how to cram all this stuff into the tinest space possible?
Old 05-16-2006, 06:34 AM
