I just got the cleaner and will be trying to clean all plugs etc that i can find.
Once that has happened, I will check the readings as detailed in CG. I will get back. thanks |
My question still stands. Why does this happen only when the engine gets to temp. does not occur when cold.
What is the part number for the TPS... I am having a difficult time finding it
1989 944 n/a |
In many cases you can take the TPS apart and clean it. Don't need to by a new one.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
winter-hater club member
when it gets hot, the connections seperate, due to bad solder or what have you.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
