how to clean injectors???
all of my injectors on my 84 944 are stopped up except for one does anyone know a way to clean , please help!!!
Old 06-05-2006, 01:58 PM
Send them to I did, and they work great. Or try this http://www.pelicanparts.com/techarticles/944_fuel_injector_clean/944_fuel_injector_clean.htm
86 Red 944(sold)
85.5 Red 944(sold)
Old 06-05-2006, 02:29 PM
thanks just what i needed to know
Old 06-05-2006, 03:02 PM
SoCal Driver's Avatar
Back flush them with compressed air. Take the plastic "hat" off of the discharge, fit a piece of gas hose to the end and clamp it. Fill the hose with solvent and apply 100 psi of shop air. The intake screen on the other end is what usually gets clogged with junk. Also means that your other injectors have crud in the screens as well as the fuel filter.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-05-2006, 04:15 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
yes it is crucial to get power to the injector so it opens up, this step was not in my instructions and i ended up with a large exploding noise and a fine mist of carb cleaner on everything within 10 feet of me.
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 06-06-2006, 09:30 AM
Back flushing the injector does not require any electrical connections. The return springs on the pintal are very weak. A good piece of gas tubing will take the 15 psi to back flush them. This does not take into consideration a totally stuck/clogged pintal. However in the last 37 years that I've backflushed injectors (actually a VW tech bulliten) I've not encountered a totally clogged injector. Others seem to have had that bit of luck.
Old 06-06-2006, 10:51 AM
ya the strange thing is they are back on the car and the car runs normal. maybe ill try to redo this some time.
Old 06-07-2006, 10:21 AM
