944 power window problem
My power windows stopped working....help... I checked the fuse...it was fine...I replaced it anyway but still no good....is there a hidden relay or something......???? the motors are good....I can get them to work when I apply a 12 volt shot....but they will not work with there respective switches......
84 944......
Old 06-28-2006, 06:37 PM
Cars & Coffee Killer
legion's Avatar
There should be a relay for the windows in the fuse box...there is on the "late" 944s...
5 liters of VVT fury now
-Chris
Old 06-28-2006, 06:43 PM
The book doesn't show one for the 1984........
Old 06-28-2006, 06:53 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Remove the switches and clean the contact areas and I will bet they work.
This a common issue and most often solved by cleaning the gunk out.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 06-29-2006, 02:59 AM
Parrothead member
VINMAN's Avatar
Check to see if the plug separated from the window switches . If either side is out the windows wont work.
Vinny
Old 06-29-2006, 05:55 AM
I second, checking the switches, it worked like a charm for me.
Old 06-29-2006, 07:48 AM
924Sman's Avatar
If one is not connected the other will work but the mirror switch won't. At least this is how mine is. My passenger side is not connected but the drivers side works fine but the mirror switch must be in line with the passenger switch.
Dal
Old 06-29-2006, 07:58 AM
thanks guys.....I did all of the above and they still won't work
Old 06-29-2006, 08:53 AM
924Sman's Avatar
Shoot wish we could have solved it for yoiu! Oh well just give me the car and go get another one!
Dal
Old 06-29-2006, 09:37 AM
SoCal Driver's Avatar
Power window relay is under the dash right above the gas pedal.
Check this thread: Pelican oldy-924 newbie - Elec Window?
Thread is still on the opening page. Pays to keep tabs on what is being posted.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-29-2006, 10:20 AM
That did it.....found the relay right by the accelerator tucked under the dash.....the relay wasn't bad....one of the wires had worked it's way out of the connector.... put it back it and they work.....so how came the Porsche manual never mentions that relay..??????
THANKS GUYS FOR ALL YOUR HELP......NOW GET ME SOME POWER
thanks again.....
Old 06-29-2006, 03:51 PM
Knowing where the window relay is located is one of the secret hand shakes.
Old 06-29-2006, 06:07 PM
legion's Avatar
Check the PET...lots more information.
-Chris
Old 06-29-2006, 06:10 PM
Super Moderator
nize's Avatar
i thought aligning the rear plate was the secret handshake ?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-29-2006, 11:00 PM
Eldorado's Avatar
i was taught the one that showed you the secret sock locations...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-29-2006, 11:01 PM
Argyle or sport socks?
Old 06-30-2006, 07:31 AM
OK guys...there is a relay uder the dash mounted towards the top....I can hear it click when I try to cycle the lights.....the relay is black and is double in size....that is, it looks like two relays in one long housing....it has two sets of wires going to each side.....any ideas???????
Old 07-01-2006, 02:56 PM
Thought this thread was about power windows?
Old 07-01-2006, 03:11 PM
Yes it is.....any clue as to what that relay does.....it does click when I try to cycle the lights
Old 07-01-2006, 03:30 PM
Define "cycle the lights".
Old 07-01-2006, 03:47 PM
