interesting engine routine...
when i speed up to 40 mph, then slow down. around 30 mph, the engine drops its rpms down to 900 and then rebounds them up to 1300, then drops downt o 900 and rebounds back to 1300, until i come to a complete stop (transmission is auto). what is the point of this little routine? or is there something wrong with my car
btw. thanks to everyone who helped with my strut/leveling problem, the car looks and handles much better now that its all done!
84' 944
Old 07-03-2006, 11:41 AM
Is your AC on when this happens? I have the same stuff at times with my AC on. It could be the auto trans downshifting too.
Im not sure but I guarantee one of these guys may know....
Good luck
Brock
86 Zermatt 951
2001 996 twin turbo Black/Red
1986 951 Zermatt/Burgundy
Old 07-03-2006, 11:48 AM
thanks. nope AC isn't on. i thought it was downshifting too but i didn't feel any drag in the engine when it did this.
on a side note, a mechanic put "check lower right arm bushing". how many bushings are on the suspension? and are they hard to change? and should i do the change before an alignment?
84' 944
Old 07-03-2006, 11:50 AM
bad tps
Good luck, George Beuselinck
Old 07-03-2006, 11:55 AM
would the tps affect performance?
84' 944
Old 07-03-2006, 01:56 PM
yep
Old 07-03-2006, 02:00 PM
how much and what performance? i.e. mid range, low end, torque, acceleration?
84' 944
Old 07-03-2006, 02:01 PM
Naw, it's not important, it just tells the dme when you have your foot on the gas, and when it's floored, and when you have your foot off the gas.
I can't imagine that the dme not knowing that would make any significant difference in performance.
Old 07-03-2006, 02:37 PM
Back from Beyond
Try unplugging the TPS and see if the issue resolves itself. Then you'll have the culprit.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-03-2006, 03:20 PM
Eldorado's Avatar
same thing happened to me... it was the screw/valve next to the throttle body that was too loose..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 07-03-2006, 04:49 PM
would the TPS affect gas mileage?
84' 944
Old 07-04-2006, 12:38 AM
Back from Beyond
Yes, it would somewhat, but it simply sends the DME throttle-on, idle-on or full-throttle-enrichment signals. See George's note.
All others GONE!
Old 07-04-2006, 09:07 AM
so in theory....if my TPS was really bad. i could have my foot off the gas, but the TPS telling my dme that im at full throttle and some extra gas would be burned (worst possible scenario probably not even plausible)
84' 944
Old 07-04-2006, 11:55 AM
Back from Beyond
Well, the DME's gullible - it'll believe pretty much anything the sensors tell it. I doubt to the extreme in your example, but it could be confusing the DME.
All others GONE!
Old 07-05-2006, 11:07 PM
do u think i should change it?? worht the 90 bux
84' 944
Old 07-05-2006, 11:12 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If it isn't broke, then don't fix it. I think there is a routine in Clarks garage that tell you how to check it. If it checks good, then look for something else. Maybe what Eldorado suggested or the Idle control valve.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-06-2006, 07:32 AM
