interesting engine routine...
when i speed up to 40 mph, then slow down. around 30 mph, the engine drops its rpms down to 900 and then rebounds them up to 1300, then drops downt o 900 and rebounds back to 1300, until i come to a complete stop (transmission is auto). what is the point of this little routine? or is there something wrong with my car
btw. thanks to everyone who helped with my strut/leveling problem, the car looks and handles much better now that its all done!
84' 944 |
Is your AC on when this happens? I have the same stuff at times with my AC on. It could be the auto trans downshifting too.
Im not sure but I guarantee one of these guys may know.... Good luck Brock 86 Zermatt 951
2001 996 twin turbo Black/Red 1986 951 Zermatt/Burgundy |
thanks. nope AC isn't on. i thought it was downshifting too but i didn't feel any drag in the engine when it did this.
on a side note, a mechanic put "check lower right arm bushing". how many bushings are on the suspension? and are they hard to change? and should i do the change before an alignment?
84' 944 |
bad tps
Good luck, George Beuselinck |
would the tps affect performance?
84' 944 |
yep
how much and what performance? i.e. mid range, low end, torque, acceleration?
84' 944 |
Naw, it's not important, it just tells the dme when you have your foot on the gas, and when it's floored, and when you have your foot off the gas.
I can't imagine that the dme not knowing that would make any significant difference in performance.
Back from Beyond
Try unplugging the TPS and see if the issue resolves itself. Then you'll have the culprit.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
same thing happened to me... it was the screw/valve next to the throttle body that was too loose..
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
would the TPS affect gas mileage?
84' 944 |
Back from Beyond
Yes, it would somewhat, but it simply sends the DME throttle-on, idle-on or full-throttle-enrichment signals. See George's note.
so in theory....if my TPS was really bad. i could have my foot off the gas, but the TPS telling my dme that im at full throttle and some extra gas would be burned (worst possible scenario probably not even plausible)
84' 944 |
Back from Beyond
Well, the DME's gullible - it'll believe pretty much anything the sensors tell it. I doubt to the extreme in your example, but it could be confusing the DME.
do u think i should change it?? worht the 90 bux
84' 944 |
If it isn't broke, then don't fix it. I think there is a routine in Clarks garage that tell you how to check it. If it checks good, then look for something else. Maybe what Eldorado suggested or the Idle control valve.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
