Send a message via Yahoo to asudds
No Spark issue HELP 8V 2.5L 924S
I have a 924S that is giving me some trouble. I have a signal processed from the DME since the Injectors are firing as required and the DME relay and fuel pump is working fine... The fuel system is all confirmed.
For spark, I replaced the coil with a known good one and replaced the cap and rotor but it seems the non-spark is being caused by a fuse/Computer/loose connection under the dash (where all this is located on the 924S.)
Any suggestions would be a great help. It seems I can get it started if wiggle wires/tap on Computer and roll fuses under the dash. But it will cut out and quit when it feels like it.
Any advice or help would be appreciated.
Aaron
atsudds@cogeco.ca
Old 07-11-2006, 04:30 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Check the inside of the computer for soldering issues at the ribbon(grey wire loom).
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 07-11-2006, 04:43 AM
Is it a common issue for the DME to fail... If so I'll try swapping it with another one.
Aaron
Old 07-11-2006, 04:58 AM
924Sman's Avatar
Not often but does. The ribbon is a known area to break.
Dal
Old 07-11-2006, 05:43 AM
SoCal Driver's Avatar
To check that it is a DME problem rather that a wiring problem run a jumper from the batteries positive terminal to terminal #15 (black wire) on the coil and see it it will spark.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-11-2006, 08:00 AM
SoCal, can I run a jumper and drive it that way in case of emergency?
Does the DME do anything more than provide a 12V supply to the Coil? Like I said, the injector pulse seems to be firing ok.
Thanks,
Aaron
Old 07-11-2006, 09:04 AM
The DME provides the ground and allows the system to run. Sounds like you need to both thoroughly check the wiring and if ok, substitute a DME.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-11-2006, 09:19 AM
Swapped the computer with a known good one... so far so good...
I'll try and fix the old one.
Aaron
Old 07-11-2006, 11:04 AM
If the problem recurs, it may be the ignition switch. I had a similar experience with my 924S and wound up wiring a toggle switch across two of the ignition switch poles. (I was at Sebring for a PCA race.) Five years later, the toggle switch still works.
Old 07-11-2006, 12:39 PM
DME had obvious cold soldier joints on the power transistors. Must have been the problem....
Old 07-12-2006, 04:33 AM
