fastfredracing's Avatar
16 valve pistons in 8 valve motor???
Anyone ever used 16 valve pistons in their 8 valve motor, I think they are a whole compression point higher. Maybe have to eyebrow the pistons for valve clearance???. Just wondering
No left turn un stoned
Old 07-28-2006, 07:05 PM
Zero10's Avatar
Send a message via ICQ to Zero10
If you are running a full standalone system you could get away with bumping up the CR, but on the stock DME, you will probably get lots of knock.
Looking at a set of 16V pistons side-by-side with N/A 8V pistons, it actually looks like the 16V pistons would yield a lower compression ratio, unless they moved the wrist pin location. It's tough to tell.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 07-29-2006, 11:23 AM
winter-hater club member
nynor's Avatar
just move the DME adjuster to retard the timing a couple of degrees...
"COOL PRIUS!" - Nobody Ever
Old 07-29-2006, 12:18 PM
using 16v pistons with a 8v head was looked into several times before (no surprise). the 16v head's valve chamber volume is less than the 8v head’s volume. so it's the 16v head that is really responsible for the higher compression ratio…not the piston.
actually this is a fact. IIRC using the 16v piston with the 8v head reduces the c/r to somewhere around 8 to 1
Tom
Early '85 944
Old 07-30-2006, 08:32 AM
Zero10's Avatar
Putting a 16V piston side-by-side with a turbo piston, the dishing is pretty similar. I would say that 8:1 is a fair estimate. The wrist pin location is indeed the same, I checked.
Buy my parts!
Old 07-30-2006, 08:35 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Ahoy there, Fred. Good to see you on Pelican.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-30-2006, 09:28 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Why not simply get the 8v head shaved with your stock pistons. You can jack up the c/r all you want that way.
Black Cars Matter
Old 07-31-2006, 12:31 AM
Zero10's Avatar
You can't deck the head very far before you require an adjustable cam gear to keep the motor in proper time.
That said, you will see a marginal gain in CR even by doing so,
i.e. 9.6:1 - 9.7:1
Custom pistons are the way to go if you must crank up the CR, but I am really starting to wonder why you would want to.
Buy my parts!
Old 07-31-2006, 12:22 PM
fast924S's Avatar
Send a message via AIM to fast924S
Just get a set of 88 pistons or some euro's. Im swaping my 87 924S 9.5cr pistons to the 88 10.2. Im thinking with high octane gas I should be ok
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-31-2006, 02:39 PM
Burn the fire.
Brando's Avatar
By high-octane, you mean 91?
I have a feeling though, you won't have a knock sensor to retard the timing...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-31-2006, 09:06 PM
Zero10's Avatar
^^^ Exactly why I suggested standalone. Knock starts to become an issue with the higher CR.
IIRC, the S and S2 motors had a knock sensor.
Buy my parts!
Old 08-01-2006, 01:33 PM
fast924S's Avatar
True, I think it all depends on how much higher you go, My thinking is running 10.2 with 91 octane, I should be ok, But If Im not I can always turn the FQS back one, Or find a piggy back from split second to chang up the timming. Ot as Zero and many others have said just go stand alone
Old 08-01-2006, 02:46 PM
