Writer/Teacher
Help identifying parts
I bought a 944/951 parts "grab bag" from eBay, mostly for the bolts/nuts/washers and other nickel-and-dime stuff that I really don't want to worry about with my engine build. Well, the grab bag came with some other very serviceable parts like shift levers, tensioner bars, unused oil filters, etc.
Some of the parts I don't recognize, however. Wondering if you all could help. 1) Chinese throwing star? 2) Some kind of vacuum stabiliser? 3) Something having to do with vacuum? 4) No idea. 5) No idea.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Pic #1 Fan Cover for alternator
Pic #2,#3 Worth with each other. They are part of the Fuel Evap system. located Near the Brake booster, off to the right on you're 83 944.
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Writer/Teacher
Also, is this a Porsche item? Looks like some kind of light switch, but I can't find any info on it:
#1 Alternator fan (as previously stated)
#2 Check valve for brake booster vacuum line #3 charcoal canister purge valve with Idle Air Control Valve connector (that is the terminal you jump to set the idle) #4 & 5 Heat shielding for exhaust\catalyst #6 Series 2 944 headlight switch AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Writer/Teacher
Thanks for the info, guys
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
