GostRidr's Avatar
S Reference Sensor Help
I am working on an intermittent hard/no start issue with my 16V. I may be having a problem with my ref sensor. I've taken off the manifold and want to make sure it is in adjustment but I don't see a way to adjust. Can someone confirm that the S doesn't have a height adjustment? If not, does anyone have any idea why, upon turning the key instead of bouncing the tach goes up to 6000 rpm briefly?
Thanks for the help!
Peter
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 08-04-2006, 02:49 PM
The S and S2 motors do have a height adjustment, 0.8 mm, just like the 8 valve cars.
Good luck, George Beuselinck
Old 08-04-2006, 04:00 PM
SoCal Driver's Avatar
Get a mirror. The whole bracket moves. It's bolted to the back of the engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-04-2006, 04:37 PM
McFly944's Avatar
A little off the subject of sensors, but I did happen to come across the sunfoor part you needed(the little microswitchs in the rear, and the grey pressure switch in the front). So the next wrenching GTG I'll have it with me. Also if you talk to Bill let him know I may have found him a inexpensive cam for his turbo.
Craig -
86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties
Past:
89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car
Old 08-06-2006, 06:47 PM
GostRidr's Avatar
Hugh and George,
Thank you very much for the advice. I never even thought of a tool with a mirror on the end and easily found one at the local store. I know that the gap needs to be .8 but I can't find the adjustment screw to adjust the whole sensor up and down. However, I did find a hole bunch of tiny shavings on the bottom of the sensor. I cleaned them off and replaced the sensor and she started right up!
This led me to more questions. Where do these shavings come from? Should the holes that are highlighted in the pic be closed with some sort of plug to prevent anything from getting in the way of this sensitive sensor signal?
Hey McFly, check your PMs!
Thanks as always!
peter
peter
Old 08-08-2006, 12:24 AM
McFly944's Avatar
Great to hear!
Craig -
Past:
Old 08-08-2006, 01:00 AM
Politically Incorrect
onZedge's Avatar
Shavings come from flywheel teeth and starter bendix gear "meshing".
Edek
'87 924S
'91 535i
Old 08-10-2006, 09:14 PM
