Turn Signals won't turn off automatically
I can't find anything in the manual or on here, my turn signals work, but don't turn off after the corner. Is it a small plastic peice like on US cars that needs replacing (if so, what's it called), or do I have to replace the whole arm?
Porsche 944
1985.5
Non-tubro
Old 08-29-2006, 09:11 AM
There are some springs and plastic parts in there which are toggled by a shaft finger. Probably something plastic is broken. Clarks garage has the write up and Paragon sell the switch for under around $80 or junk yard.
You could always take it apart and see if it could be super glued or somthing.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 08-29-2006, 10:01 AM
Eldorado's Avatar
i've tried taking the turn signal switch apart... it doesn't come apart easily..
buy a used one from a board member - that's what i did.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 08-29-2006, 03:54 PM
Ornery Bastard
Usually what I've seen happen is that the "finger" on the steering wheel gets worn and doesn't work all the time. I know that the "finger" on mine doesn't always trigger the turn-signal shut-off. Not much that can be done about that.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 08-29-2006, 04:41 PM
So there's not a rebuild kit I guess?
Porsche 944
1985.5
Non-tubro
Old 08-29-2006, 05:53 PM
Back from Beyond
Remove your horn pad - pull gently up on it till it comes free, then disconnect the horn wire. Get yourself a 24mm socket (if I remember correctly) and a long extension and remove the nut holding the steering wheel on. Pull the wheel towards you and it should slide right off the shaft. You may wanna mark its location before you do this, but I just set the wheels straight and replace the steering wheel straight. Once you've got the wheel off, have a look at the back of it. Screwed to the back you'll find a plastic ring with the tab on it that cancels the turn signal. It's held in place by three screws. If it's broken it's an easy fix - remove screws, replace ring, replace steering wheel. Torque big nut to 30 ft/lbs (better check me here). Don't forget the horn wire. If you get that far into it, you'll be able to see the turn signal switch's innards and whether or not something's broken there.
HTH!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-29-2006, 06:14 PM
Thanks guys.
Porsche 944
1985.5
Non-tubro
Old 08-29-2006, 07:01 PM
SoCal Driver's Avatar
Just for the knowledge base; you 'cancel' turn signals.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 08-29-2006, 07:07 PM
bearone2's Avatar
other than separating the 1/2's on the old ones, not much to take apart.
if not broken off, wrap the stud with electrical tape to trip the cancelling mechanism.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-30-2006, 03:01 PM
white tab
what i think most of you guys are missing is most often, the back of the steering wheel that black tab that sticks out is fine, the majority of times, the white tab it is plastic that is the "cancelling" mechanism is supposed to stick out into the path of the black tab and get cancelled out is most often broken or worn off. so stop addressing....tape on the back of the black tab etc.......the real fix is fixing the white plastic tab that is on the lever itself.....i dont how to repair this, it is embeded in the sterring part, but if you can get a replacement either new or used, it should fix the problem........but again taping back of steering tab does NOTHING is your white tab is broken.....
Old 05-26-2011, 08:50 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
electrical tape?
We all know what electrical tape does when it's subjected to heat like the type we have in car interiors in the sun. It's not meant for repairs, period.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-26-2011, 10:17 AM
