Blondie's Avatar
No start or high idle - Temp Sensor
With the temperature sensor plugged into its mate on the block, the motor wont start. I can crank and crank and it'll chug here and there but just wont seem to catch. Playin with the throttle helps, but it'll quickly idle down to a shudder and die.
With the temp sensor unplugged, it'll turn over first crank and instantly rev to 3000 rpm where it'll idle forever. The throttle is responsive at this point, but really slow to kick in.
Bizarre, I know.
Doctors, grab your scalpels. Its time to diagnose.
'86 Porsche 944, Guards Red
Nancy is currently [going in for the final 'once over' this week..]
AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL
Old 09-20-2006, 07:59 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The sensor plug is shorted. (more than likely corroded at the plug)
Put a meter on the leads on the plug to test.
The wires shorted = ultra rich. The dme thinks its freezing out and tries to richen up the mixture.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-20-2006, 08:51 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
And I have a new one you can snag...email if you want it.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 09-21-2006, 01:00 AM
Blondie's Avatar
The block is from an '83...everything attached to the block is from my '86. Uses the same size plugin as everything else on the wiring harness. Perhaps theres a difference in calculations by the DME as its looking to measure block temp and not the water temp, right?
Old 09-21-2006, 08:00 AM
SoCal Driver's Avatar
The DME temp sensor is the same for all 944's.
The gauge temp sender is different. Use the larger of the two pins on the gauge connector for the single pin on the early gauge temp sender.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-21-2006, 11:27 AM
