GostRidr's Avatar
Proper wire splicing
I am replacing the 4 pin connector to my headlight motor from my harness. I want to take a stab at avoiding duct tape like the PO. What is the correct method to splice the new (used) connector in? Solder, heatshrink, connectors, other?!
Thanks!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 09-22-2006, 05:35 PM
Dtchy's Avatar
Solder and use heatshrink tubing.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 09-22-2006, 05:36 PM
GostRidr's Avatar
Nice response time Dtchy - Thanks! I've seen cold soldering. Does it matter which one?
peter
Old 09-22-2006, 05:53 PM
Eldorado's Avatar
nope dont think so.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 09-22-2006, 09:52 PM
Yep what they said. I put about double the amount of splice in length of heat shrink put it on wire and push Way up so it doesn't melt when soldering. Some people use heat gun but myself and many tech's just roll the soldergun near the Base (where it's cooler) over the placed heat shrink, and Viola. Never used the "cold solder gun" but it look nice for small wires. Won't shrink the heat tube thoe.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 09-23-2006, 03:22 AM
Rrrockhound's Avatar
The cold solder gun sucks. I bought one, tried to use it, threw it away in disgust. I really wanted to like it. The concept is OK, but it only heats the solder, not the wires. So the solder never really flows into the braids. What good is that?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 09-23-2006, 07:57 AM
Zero10's Avatar
Send a message via ICQ to Zero10
You mean the cold heat soldering gun?...
It's crap. I've been given 2 and both sucked. At least with one of them I was able to strike a small arc..... that worked better than the soldering iron until the whole tip and plastic assembly melted right off of the tool.
Get a small soldering gun for wire repairs, it will make your life easy.
Strip as much of the wire as necessary, ALWAYS apply flux. Don't bother with rosin core solder, actually apply a flux to the wires, especially when they are 20 years old and possibly have water infiltration. Then heat the wires up, apply solder and shrink wrap the soldered area.
I guess I gave those instructions slightly backwards, since you usually have to slide the shrink wrap on before you splice, flux then solder. Normally I use lenghts of shrink wrap about twice the length of the stripped/soldered area. I also usually apply it two layers thick. I slide one piece of shrink wrap down each side of the splice before I start, and hold the wires in my hands to absorb the heat (keep your hands back a few inches).
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-23-2006, 09:15 PM
