Installing A/F gauge
I need to install a A/F gauge in my turbo, but I'm not quite sure what is needed.
I went off to lindsey racing and bought an analog display
Link -> http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=IM-3731&Category_Code=
Here's the description on it -
"Analog Display
52mm, 8-18 AFR needle gauge driven by LM-1 analog output. **Requires "Analog Output Cable" Not included** "
What else will I need, and what do I do with the other stuff?
Thanks guys!
-Alex
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 11-16-2006, 01:51 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You still need this to run it.
http://www.innovatemotorsports.com/xcart/product.php?productid=16139&cat=261&page=1
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-16-2006, 02:53 PM
Eldorado's Avatar
yea, what you bought was just a display, not a gauge.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-16-2006, 02:57 PM
nickd's Avatar
$60 for an analog Westach A/F gauge?? Porsche owners really are gullible...
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 11-16-2006, 04:13 PM
Where do I install the wideband o2 sensor?
Old 11-16-2006, 05:10 PM
Eldorado's Avatar
nickd, back off.
poz, my guess would be to install it where your stock one is... then again, I'm not sure on that.
Kyle
Old 11-16-2006, 06:11 PM
That's why I asked what else I needed
Old 11-16-2006, 06:46 PM
What I got so far is I need to put the wideband o2 sensor in between the header and the cat (which is deleted).
I'll see if I can put it as close to the header as possible.
Old 11-16-2006, 09:54 PM
ae1969's Avatar
You want to put it just past the down pipe coming from the turbo.
The crossover segment where the stock o2 goes gets too hot.
Life expectancy decreased.........
but then again I am running two widebands. One in the stock location and one on the down pipe. Long story. But it makes for interesting logs........ guess which one runs 0.5 leaner.
Old 11-16-2006, 10:10 PM
nickd's Avatar
Ah, that did sound harsh - was meant to be a bit tongue-in-cheek. Just wanted to let you know that you can get the gauge through Westach much cheaper. Or at least you could when I picked one up years ago.
Zeitronix also makes a nice wideband kit. I've not heard good things about Innovate's customer service, for what it's worth.
Old 11-17-2006, 04:52 PM
rberry951's Avatar
Poz, see if you can send that back. I believe the unit I'm going to go with is this:
http://www.plxdevices.com/products_SMAFR.htm
The combo unit with the gauge pictured is $269.00 That is pretty reasonable. It also has various logging capabilities.
You want to put your wideband O2 just past the downpipe about 8-12 inches in front of the cat or test pipe. Putting the wideband in the stock O2 sensor bung will kill it as stated above, and will also give erratic readings because of the turbulence between the header and turbo.
Oh, that was pretty much stated above too.
ohwell
I'm too lazy to delete...
Russell Berry
1986 911 Carrera Targa Widebody/Slantnose
Old 11-17-2006, 06:16 PM
O good - Thank you russell, I was really hoping for a sub $300 deal D
That's perfect, even has a digital display -- I was just looking at Zeitronix, and it seems they have a close to $300 with a egt also -- Would that be worth my money?
Both seem like a good deal.
Thanks again guys!
-Alex
Old 11-17-2006, 06:21 PM
Loquat15's Avatar
Send a message via AIM to Loquat15 Send a message via Yahoo to Loquat15
the Zeitronix deal is well... $400... unless... you dont want the LCD screen... the LCD screen adds 100 bucks to that kit you were looking at.
It's probrably still a good deal... you'd just have to buy all that extra stuff with it... boost sender, EGT sender, screen... well yeah.. go figure.
Oh, for EGT's its like 77 bucks for the sending unit... for the boost sender its 109 bucks...
if you want it all...
$585 dollars
minus the boost sending unit its
$508
BAHhhhhh decisions... something tells me i'd end up getting a bunch of different sending units and gauges... fudge.
1986 Porsche 951 Autothority Stage 2, Cat Delete, Shimmed Wastegate, hampsters on wheels
1985 Porsche 944 Stock (first car owned, Sold)
Old 11-23-2006, 07:31 PM
