Sweeny Todd's Avatar
944 cylinder liners
Howdy,
Does anyone know if you can put sleeves in a 944 block? Anyone seen it done anywhere?
Hal
Old 11-11-2006, 09:13 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Yes, that can and has been done.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-12-2006, 12:59 AM
Company outta LA does. http://www.cpperformance.com/ cool stuff. Then you could stick in some JE pistons or something..
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 11-12-2006, 07:00 AM
Thx
Hal
Old 11-12-2006, 07:57 AM
Another I think called Darlington. Search the Turbo Site for better Sleeve talk. They Bore and Sleeve and sometimes Stroke.
Old 11-12-2006, 09:01 AM
winter-hater club member
nynor's Avatar
MID sleeving is the way to go, in my opinion.
"COOL PRIUS!" - Nobody Ever
Old 11-12-2006, 09:25 AM
What is MID sleeving?
H
Old 11-12-2006, 05:33 PM
nynor's Avatar
do a search in the turbo section. i think there are some pictures.
modular something something. they take you block, machine the existing cylinders completely gone, insert replaceable cylinders into the block, and voile! you can then get a matching set of pistons to make an 2.7 liter engine, if that's what you want, at practically any compression ratio.
try this:
http://www.cdpautomachine.com/ecatalog/darton_porsche.html
Old 11-12-2006, 05:40 PM
Go straight to the source...Darton Sleeves
That is who makes the Modular Integrated Deck (MID) sleeves. That is what everyone uses on the 944/968.
Old 11-12-2006, 06:17 PM
Do any of you guys know if it's legal in Spec944?
It looks pretty invasive - almost like a new block inside a block.
H
Old 11-14-2006, 04:41 PM
Mike B's Avatar
I'm sure Chris White can help you out.
http://www.944enhancement.com/index.html
'86 951
'88 928S4 - the project
Old 11-14-2006, 05:27 PM
nynor's Avatar
invasive?! and sleeving isn't? i can't wait till i score a cylinder and can justify the expense to have mine done... 2.7 liter turbo madness here i come!
darton is claiming crazy boost, 20 pounds and higher, because the cylinders can take it, they don't 'walk' like stock cylinders do, and the head gasket seals better... anyone here want reliable 400 HP, plus?
Old 11-14-2006, 08:53 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I thought if you went with stock bore sizes that you were fine for spec racing? Of course, you might need to still run stock pistons as well.
That said, how do they go about checking that? I mean, if you ran 106mm bores instead of 100, how could they tell?...
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-15-2006, 09:41 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Reeves Callaway did this back in 1983-84 with his Callaway conversions. It was far simpler (and less expensive) to get 8.0:1 c/r pistons made in the U.S. at that time that were for use in steel bores, not alusil bores.
I'll probably end up going with a steel-sleeved block with about 8.5:1 c/r pistons, bored over and a 3.0L crank. Should give me about 3.1L give or take. It won't be 100% authentic Callaway (which were 100mm bores, retaining the 2.5L displacement), but it'll sure go like a raped ape under 18 psi of boost!
I've got other things to do first, but that's the plan anyway.
Alternatively I could always plug in 951 pistons without sleeving, but that's so unsporting. . .
Black Cars Matter
Old 11-15-2006, 11:59 AM
Anyone know the price of putting in these sleeves?
Tom
Old 11-15-2006, 02:01 PM
nynor's Avatar
the cost was listed in the page link i provided, above. i think it was about $1500 with the new cylinders bored, pistons to fit, and rings.
Old 11-15-2006, 04:05 PM
Well. Mostly, you'd just be a lot faster than everyone else and eventually you'd get caught in a random tear-down inspection at impound.
If you're not faster then, well, I dunno. I suppose it doesn't matter.
H
Old 11-18-2006, 04:51 PM
Zero10's Avatar
H
Do they seriously tear your engine down to check?... That is scary!
Buy my parts!
Old 11-19-2006, 01:16 AM
They do in most racing motorsports in the US. In NASCAR, they look them over before the race as well as the end. Same in NHRA. They check your car previous to the race, check your fuel between each run for the right mixtures, yada yada yada...if you are consistently faster than everyone, they tear them down at the end of the race and you may not get your car back for a few days while they look everything over. If any of the competitors thinks you are outside the rules, they can request a tear down on not just the engine but any part of the car...of course if you are legit, they have to pay for the rebuild.
Tom
Old 11-19-2006, 10:08 AM
lateapex911's Avatar
First, lets just assume nobody would even want to run an illegal bore, (or whatever) in club racing. Club racing is diffferent in nearly every sanctioning body than Pro Racing.
I pro racing, the sanctioning body is responsible for determining a teams legality. They can do pretty much whatever they please to do so.
In club racing, the competitors are tasked with an honor sysptem. If they choose to go outside that and cheat, the other competitors job is to file a protest. Each sanctioning body varies on the specific procedure, but in very rough terms, you meet with the protest stewards when you write your protest, and decide on what rule is being broken, how the protest will be written, and what proof you will accept that the car is legal, or not. Then, the protestee is met with, and via the Stewards, a protest bond is set that is agreeable to all parties. Obviously that varies depending on the protest, but for a bore protest, it would need to cover the expense of the head removal, time and materials. Dependig on the car and the complexity, that could be anywhere from $500 to ????.
At that point the car is taken to a nuetral area, and the stewards observe the process, and make a judgement.
If illegal, the bond (less a fee, ussually) goes back to the protester. If legal, the protester loses the bond, and the fees.
It's rarely a simple process, LOL.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-19-2006, 10:27 AM
