shikzachaser's Avatar
That should work
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 01-20-2007, 01:44 PM
Eldorado's Avatar
steve, if i wanted to add a similar setup for my fogs, would I just make an identical harness that you have, but change the bulb connector?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-20-2007, 02:34 PM
That would work, make sure the realys are not exposed to any elements.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 01-20-2007, 05:22 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
I wish I knew how to do wiring stuff, I'll probably just end up getting a rennbay kit.
Keith
1986 Porsche 951
Old 01-21-2007, 12:30 PM
Eldorado's Avatar
Keith, follow the link i posted... it's a pretty clear/concise instruction on how to build a similar kit =)
I'm sure people like Steve, or myself (where I can) would love to give you a hand if you chose to build your own..
Kyle
Old 01-24-2007, 12:30 AM
Eldorado's Avatar
the harness arrived today, and this thing looks effen awesome... small things amuse me, obviously, but yea... very classy and professional looking.
steve, check your pm's...
Kyle
Old 02-08-2007, 02:49 PM
Not Special
Useless without pics!
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 02-08-2007, 03:40 PM
Eldorado's Avatar
look back in the thread
I haven't installed it yet.... i'll report back when i do.
Kyle
Old 02-08-2007, 04:46 PM
Not Special
That's what I'm gettin' at, Kyle!
Old 02-08-2007, 08:40 PM
Final light setup
The final light setup includes these 120W driving lights that come on w/ the high beams (they can also be defeated w/ a dash switch). The use of 6 headlights is totally a no no in Missouri but is really really bright for those night time twisty adventures.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 02-13-2007, 05:52 PM
Eldorado's Avatar
started installing the harness today...
this thing sure is nifty... but one drawback that i haven't overcome yet - my 83 cant have wires tucked under the nose... right where the hood latch is, it's blocked off so nothing can pass through... i'm trying to figure out another way to route it... stay tuned
Kyle
Old 02-23-2007, 01:29 PM
Not Special
Kyle, let me know how you do that. I have the same problem!
Old 02-23-2007, 01:47 PM
Eldorado's Avatar
I went back out, but the sun is starting to set and it's gettin' chilly out there... I'll go back out over the weekend hopefully and tackle it..
anyone have any ideas?
Kyle
Old 02-23-2007, 01:56 PM
Not Special
I'm not sure meself, but take pictures. :P
I might try going under the car, but I won't be able to try until the weekend (no jack yet).
Old 02-23-2007, 02:00 PM
Routing
Try it like this, it works on mine :
There are holes in the metal where you can tie wrap the harness for the right light in front of the light bar. The new plugs go in from the back of the light housing. Make sure things don't interfere w/ the moving parts of the lights duhhhh.
Relays ready to be hidden
Relays tuck into the holes in front. Ground goes to the 6mm threaded stud already there.
Alternator routing.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Eldorado's Avatar
Steve, your pic looks exactly like the problem i'm running into.. how did you get around it??
Kyle
Old 02-23-2007, 02:08 PM
Eldorado's Avatar
ohhh i see the problem.
on your car, on the first page, you have smaller wires.. you didn't put that fancy braid around the outside, so it fit right in the notch between the nose piece and the hood latch....
I cant stuff mine in there.. so i'll have to tie wrap it....
Kyle
Old 02-23-2007, 02:11 PM
You will need to take the air cleaner box loose and go under it. It should work fine then. Just tie wrap the right side one in front of the light bar and go in from the back of the light. I made the harness longer than necessary to allow you to route around things. Sorry for you to be the guinea pig. Good luck and have patience, it will work. Relish the fact you have the only one ever produced that has been outside of my garage. I have one exactly like yours on my car now. I liked the look of the braided one much better. Mine is easier to do in that I trashed the old air cleaner system for a K&N cone, it gives you a lot more room, sounds good too.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 02-23-2007, 02:14 PM
Kyle:
If you have too many problems PM me and I'll send you my phone #.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 02-23-2007, 02:18 PM
Eldorado's Avatar
yep, the air box is out... this was just a prelim shot that i took before the install..
i'm sure it'll work great once i tie wrap it... i'll do it tonite hopefully, after dark.
I still have the stock connector at the bulbs hooked up because i want to take before shots... now it's just a matter of hooking up the new harness to the new bulbs...
you da man, steve hehe
Kyle
Old 02-23-2007, 02:19 PM
