how to remove 944 2.5l engine
how do you remove 85 944 N/A engine using a engine crane. what brackets to use and where do you bolt them on etc.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Greasy Member
^ +1
The front of the car needs to be raised, then the engine lowered out from the bottom. If you don't like the looks of that, you can search the forum and find the horror stories of people that have tried to pull them from the top Good luck! -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
A few tips when removing from the top:
Remove the hood; 4 bolts and 2 shocks. Leave the steering rack loose after removing the steering linkage. Remove the fans and radiator. Once the engine is supported from above, remove the engine mounts from the engine block. You will have to tilt the engine a fair amount, (forward and backward, and left to right) to clear the headlight assembly, and it is a tight fit. Go slow, have help, and don't bang the oil pan. Everything else is covered in Clarks-Garage. There are two 'rings' on the engine to be used for lifting. One is at the back of the valve cover, and the other is near the left front engine mount. Good luck JM
thank you
thank you for the info
meister member
I dropped my 2.5L out from the bottom while still attached to the cross member. After the motor was on the floor I lifted the front of the car with the engine hoist and slid the motor out by hand. The motor was dropped onto a piece of plywood so it slid out pretty easy.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
I took my engine out the top. I had already removed the clutch housing, but it won't slide off the back of the engine until you loosen the motor mounts and raise the engine a bit so it will tilt back. It's a tight fit, but it will come out. Hood has to be removed as previously stated. Went back in through the top with clutch housing in place, but it was a very tight fit. Being able to tilt the back of the engine down was key.
'83 944 '87 951 |
I have done it both ways.......
For some reason I liked it from above....... but the bottom is actually easier.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
out the top twice for me. Only hitch was because I wasent told i had to remove some bolts that I didnt know existed. Other than that, the natual weight of the engine tilted it for me and out the top it came, easy as pie. Remove the radiator and there will be no prob
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
I pulled mine from the top as well. I have an automatic and I think that gave me a little more clearance but it was really easy to pull it from the top. Take the radiator out and I pulled the crossmember but I'm not sure I had to.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I have removed a couple
![]() All came out the bottom... Did it once out the top and won't ever do that again.
Good luck, George Beuselinck |
