tnporsche's Avatar
Question how to rebuild front struts
How do I get the cartridge out?
Do I bend back the housing?
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 01-25-2007, 02:36 PM
From the picture it looks like you have to replace the whole strut, not just the cartridge. The only rebuild type that I have seen are threaded, the cartridge is held in by a threaded cap which is usually so badly rusted it never comes apart anyway.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 01-25-2007, 06:07 PM
tnporsche's Avatar
Thats kinda what I thought being it looked very sealed.
Lowell
Old 01-25-2007, 06:12 PM
Custom User Title
Dave L's Avatar
from paragon products tech article
The 911, 914 and some 944’s featured a rebuildable front McPherson Strut. Instead of having to replace the entire strut unit, you will be able to merely replace the strut insert that is on the inside of the strut housing. You will know that your strut is rebuildable by looking in the area where the shiny piston rod goes into the lower strut housing. On rebuildable struts, a screw on cap (gland nut) is used to hold the insert into the lower strut housing. You will know the gland nut is removable because you will likely see a few threads sticking up on the cap. 1965-83 cars used a male threaded gland nut, and 84-89 cars used a female threaded gland nut.
Old 01-25-2007, 07:25 PM
tnporsche's Avatar
Auto Z sold me these inserts. I guess I should have done a little research first. (check with pelican buddies)
I was going to change them just as a "why not" kinda thing. The current struts seemed to have little resistance to bumps in the road. (bottomed out)
Is it true the only way to determine if the struts are bad is if its leaking fluid, or shaft scoring????
(If true, I may just put these back on )
Lowell
Old 01-25-2007, 07:40 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I will start this by stating up front that I am not a suspension guru...but I think if the suspension is bottoming out, I would replace them (although I realize they are not cheap) and also check my springs to make sure they are not weak. I would think they play a large part in whether the car bottoms out from a bump in the road.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-25-2007, 08:48 PM
