Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Sensor connections
Hey Friends.
Small issue. The connectors to my speed and reference sensors are cracked and held together with superglue, gasket sealant, duct tape and wishful thinking. I don't need new sensors as the old ones are fine. It all works, but it doesn't give me a secure and confident feeling.
Does anyone know where I can get new connector ends? Should I just replace both sides while I am at it? Has anyone done this before? Any suggestions for replacement connectors?
Thx in advance.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 02-14-2007, 09:51 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Plug 022.906.231.A
spring N 903.353.03
Socket 022.906.233.B
You will also need the wire ends but I'm not sure which ones those are. If anyone has a picture of one, I can look it up. There are pictures of all electrical connectors at the end of the electrical section of PET if you want to look at yours and compare them to the pictures.
Of course a local salvage yard may have a set of leads with them on there...not sure.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-15-2007, 07:38 AM
SolReaver's Avatar
Thanks RB
I have looked through boneyards and not had much luck. These connectors are getting on 20 years old now and the plastic is really brittle. I will try 2 post pics later.
Old 02-15-2007, 09:39 AM
