S2 Headlight Problem!!!!!
Hi All,
HELP!!!!!!! I have a '91 S2 Cab and have got a strange problem with the nearside headlight - It is a euro car - The lights pop up and will work on main beam but on dipped beam there is nothing, I have tried changing bulbs and looking at fuses but these don't seem to be the problem!!!! Does anyone have any ideas as to what the solution to this weird problem is??? Any help would be appreciated as the car is currently unavailable to drive at night and in the UK now it is dark alot of the time!!! Thanks in advance |
Light switch.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
I wish I had a 1991 S2 with a headlight problem.
Red 1967 Saab "96", needs help Blue 2002 Pathfinder SE 1991 240SX-SE, auto, trans was shot - junked it |
had a problem with my 87 924S, low beams wouldnt work, only highs. I played with the wires ion the back of the fuse box a little, and vwa laa. thats my 2 cents
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
I had a problem with the nearside light pod on my cab last summer.
Basically the wiring to the lights were very tightly strapped down with cable ties around the back of the pod and the up and down movement had caused the wiring to crack right where the loom was held down too tightly.
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
My problem was the high beam switch. I had no lights on low (dipped) beam, no fogs, but on high (main) beams I had light, and my fogs worked on parking lights. I pulled the turn signal/high/low beam switch and cleaned the assembly with electric contact cleaner (aerosol can) and put it back together and the lights worked again on low (dipped) beams.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
Not Special
944cabby has an experience similar to my own...it ended up being the wires that plug into the light itself, the connectors were a little bit loose. Made sure they were fully seated, problem solved!
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen Former: 1985/1 Porsche 944 - Graphite/Black |
