Overheating question
Hey everybody.. Havent been around here much in the past year. No need no, no problems to pick everyone's brain about.
Until now. Doesnt seem to bad though and the problem is remedied, but here goes.... I overheated today, for about 30 seconds. Killed the engine, waited for the temps to come down, then drove home. The 30 degree outside air kept the engine cool for the 5 mins I drove home with no further overheating episodes. Luckily(?) it was caused by both cooling fan fuses blowing. I noticed, just prior to overheating coolant smell. My questions are - Should I be concerned about overheating for 30 seconds? Would I be looking at any head gasket damage, etc? Why would I get a coolant smell? (the coolant overflow tank was cool to the touch when I killed the engine when I noticed it overheating). And finally, why would contribue to both radiator fans blowing? Angry porsche gods perhaps... Any help, as always, is greatly appreciated. Thanks in advance.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Non Compos Mentis
Fix the fans and drive the car.
Thirty seconds is not long enough to build the heat necessary to do any damage. |
It was actually both fan fuses (#10 and #15) that blew. Had some spares, fans are operational again
Thanks for the quick reply Dantilla.
That Guy
Check the wiring to the fans for shorts, see if the insulation is cracked or frayed..etc.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
probably. overheating 30 secs, as in pegged to the redline while running says water pump not working if the exp tank was cool.
was the a/c on? when you turned the key off the temps went higher. were both fans running after you turned the key off? good luck
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
Both fuses blown meant both fan motors are on their last leg.
The fan motors are drawing current higher than full load amps. Could be winding insulation breaking down or bearings seizing up.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
And this is remedied by a radiator fan rip and replace, right? Quote:
Nope, the bearing retainer is crimped and spot welded if I remember right. Had to buy a used fan from evilbay. New motor costs a lot of money.
it's been a while back but i bought, thru here, six bl fans and the shroud for $75
New fan motors are expensive, no shroud. Did you buy it used?
i've seen the add. you notice how the non-insulated, pos, 3 bl fans are more expensive than the more efficient 6 bl's.
yes. i posted i needed it, got a pm, made arrangements for the $75. with as many parts cars around, anyone who insists on paying retail prices for the 6 bl fans.........
Um why on earth would any fan go on if its 30 degrees outside. I dont get it am I missing something.
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Why would a fan turn ON in 30 degree outside temp?
944 engines have no engine belt driven radiator fan. It will be ok if the car is always moving, but in stop and go traffic, it will overheat even in 30 degree outside temp. Where do you think the engine heat is going to even in sub-zero outside temp when you get stuck in stop and go traffic?
30 deg outside, going up a hill @3500/3rd gear/or 3500 in 4th gear, assuming the motor is at operating temp, near the middle line and the fans come on.
Ive never heard my fans going on during the winter time at all. Make no mistake I know when my fans come on. They are noisey. Am I in the minority on never experiencing the fans NOT coming on in the winter. This seems extremely odd to me.
My fans go on every time I park the car - about 30 seconds after turning off the engine. I rarely hear them come on while I'm driving but they have come on, usually in the summer but ocasionally in the winter when sitting in traffic (but being in California, we all know that there isn't any traffic here- lol).
Vern |
