Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Unhappy A/C Works but doesn't
I never gave this a second thought until today when it was foggy this morning and I went to defog the windows.
I was told by the previous owner that the A/C does not work so I never touched it and never cared to look into it. But today got me thinking that it probably works fine except one thing...
I pushed the defrost button to defog my windshield and I heard the A/C compressor kick in and turn off, turn on, turn off, on, off... etc... So I sat there and wondered if by chance that it could blow somewhat cool if I push the A/C button, but when I pushed it nothing happened. It didn't even click or light up... I push it and nothing... dead button?
I know the compressor works because it cycled on and off during the defrost. This means it MUST have pressure or else it would not come on at all, right? So there is a chance it has refrigerant, right?
SO what the hell is wrong with my A/C button???
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 03-02-2007, 08:50 AM
The charge is probably low. When the system is off, there is just enough pressure to make the switch. When the compressor kicks on, the suction pressure drops and the switch opens. (Just a guess.)
Old 03-02-2007, 09:36 AM
Gremlin85's Avatar
ok, so on my way home I did some testing. If I hold the button, the A/C cycles on and off like it would if I had the Defrost on...
jwade944, you might be right on that pressure thing. It cycles on and off way too fast to actually be working right.
I figure, if I replace the button and dump some freon in, it might work fine.
Any other suggestions???
THANKS!
Old 03-02-2007, 04:31 PM
bearone2's Avatar
put some gages on it and see if there's any pressure.
the lo pressure switch shuts it down to protect the system.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-02-2007, 04:50 PM
67l60's Avatar
dont think its youre button
pull the 2 wires off px switch jump together start ac
if all runs and compresses you need freon
1986 944 n/a hard top, black on burgundy
Old 03-02-2007, 06:17 PM
Your climate control unit's compressor switch is not latching.
The push button switch is lighted. When it's ON, it should illuminate.
Are you saying the switch seemed like it was not latching in the ON position?
If yes, the switch is bad. It can be replaced but you have to pull the climate control unit to replace the switch.
available at: http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1000242+944s2+climate control-944s2
Once the switch is fixed, then you can recharge the unit and test for leaks.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 03-03-2007, 02:13 AM
