steering rack removal issue
Havin a bit of a problem removing my old steering rack for a 1985.1 944. Seems the steering gear will not retract from the steering rack once I undo all the other retaining clamps. Tried to pry it but won't budge!!!! Any suggestions? Little frustrated!!!!
Thanks.
85 944 2003 Ducati Monster |
That Guy
Pictures? Ive got no idea what your talking about.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Where the Steering Gear Universal Joint attaches to the shaft of steering rack. I do not have pictures due to the fact that it is kind of hard to see (tight space). BTW...thanks for getting back so quickly.
That Guy
Tap a small chisel inbetween the pinch on the end of the steering shaft. Use a pry bar to gently pull the two apart.
Thanks...I will give it a shot! Used a screwdriver previously but I don't think it had enough "spread".
Thanks again!
yes, i got a long piece of steel, about 1/2 dia x 14'' long. i ground one end to a chisel point, then tapped it into the slot, this will open the dia, and allow the steering gear to drop. remember to mark the relationship between shaft , and housing, for re-assembly. boy, is that a lot of fun !
1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten. |
also hit it with some wd40 in between tapping sessions.....
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
