jezza944's Avatar
Twist method HELP Cam belt
I'm doing my belts as I type this.
Can someone tell me exactly where you twist, and do you do it with the idler pulley off? Perhaps a pic?
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 03-22-2007, 06:55 PM
Eldorado's Avatar
oye.. if you've never done this before, i wouldn't suggest it....
but I believe you twist in the center of the longest span on the belt.. with the pulley on.... but dont quote me on that.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-22-2007, 07:03 PM
winter-hater club member
nynor's Avatar
idle pulley off. i'd also spin any rollers you've removed. if they sound like a roller skate wheel, they need replacing.
"COOL PRIUS!" - Nobody Ever
Old 03-22-2007, 07:09 PM
earlr85944's Avatar
if you have to ask you probably...
never mind, get the krikit tool at a minimum.
If you already replaced the belt and used the twist method, get the krikit tool(@ $10 from napa) and double check. I've used the twist method on other cars but wouldnt use it on these cars unless you have a good feel for the correct tension already. Yeah I know some people can rebuild a motor with an adjustable wrence and a tube of silicone but they usually have alot of experience and imagine what they could do with the right tools!
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 03-23-2007, 05:13 AM
Send a message via AIM to hpaulb
Correct on the feel with experience thing. Have always used the 90 deg twist meathod with excelent results. Always do it with the completed system ie all tensioners and idlers on.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 03-23-2007, 07:19 AM
nynor's Avatar
i don't know about you, but i can see no way to twist the belt with the idler on.
Old 03-23-2007, 07:23 AM
earlr85944's Avatar
agreed, remove the idler and the belt guide
83 944....bye bye
Old 03-23-2007, 09:59 AM
nynor's Avatar
i am betting that it doesn't have the guard, as its an 84.
Old 03-23-2007, 10:02 AM
nynor's Avatar
Old 03-23-2007, 10:07 AM
earlr85944's Avatar
hopefully it does, if not maybe due for a water pump change....
83 944....bye bye
Old 03-23-2007, 10:50 AM
Eldorado's Avatar
I have to say, paul has magic fingers.. lol
he did mine near the end of summer '05... and I put the car away for the winter.. came back out start of spring '06, got the belts retensioned at a porsche shop - the values were almost bang on to spec... so his way works hehehe
Kyle
Old 03-23-2007, 11:07 AM
jezza944's Avatar
Just an update. All finished and good. Twist method with idler off is the way from a P guru I phoned to be sure.
One common fault when doing belts is overtightening the balance belt, hence the whine. The other fault is when tensioning, the tensioner can be rotated either way. From memory, cambelt is anti-clockwise and balance belt is clockwise. If the balance belt is tensioned anticlock, you can't get clearance of belt on idler, causing whine.
I also tensioned the balance belt with motor running till whine stopped, and checked and it was a neat 90 deg. And no whine at all!
Dave Jezza
Old 03-23-2007, 04:42 PM
Redline Racer
HondaDustR's Avatar
Seems to me that getting the twist method right requires "calibrating" your feel with a 9201, or similar tool first, since the belt will twist within a wide range of tensions. It's all arbitrary untill you know what the right tension twists like.
Toss many944s a PM, as he loans out his 9201 for no more than shipping charges and a well treated tool.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-23-2007, 06:08 PM
Eldorado's Avatar
exactly..
anybody can twist a belt 90 degrees, regardless of tension...
you have to know what the "right" 90 degrees feels like...
jezza, it cost me 60 bucks canadian to go to a shop and have them tension - for peace of mind I'd get it checked out.
Kyle
Old 03-23-2007, 11:49 PM
Parrothead member
VINMAN's Avatar
Im due for a belt change . I will use my tried and true finger press method!
Vinny
Old 03-24-2007, 06:22 AM
Redline Racer
HondaDustR's Avatar
Yeah, same here. I found that way to be easier to get a feel for the tension than the twisting. I had a great time (jk It was a learning experience..in the freezing cold at night! ) tensioning my belts with the 9201 and got a pretty good idea of what various tensions feel like.
exactly..
Yup.
Anyone that's tensioned with the 9201 probably knows how little it takes to change the tension a whole 1 point on the scale.
Old 03-25-2007, 08:09 AM
