Broken tensioner stud.... HELP!!!!!!
86 951. Tensioner stud had broken off at the threads on the block end. Anyone have any experience getting one out!!!
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 03-21-2007, 04:30 PM
winter-hater club member
nynor's Avatar
use an easy out? are there ANY threads sticking out?
"COOL PRIUS!" - Nobody Ever
Old 03-21-2007, 04:44 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Uhmmm there is a nut that should be flush with the block......
How did you bust that?
It depends how much is showing. Heat is your friend....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-21-2007, 05:06 PM
it broke right past the nut. In other words.....I pulled the front part of the stud out with the tensioner, locking nut on front, and the back nut that is flush with the block, plus the shaft of the tensioner. It broke right at the threads on the block side.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 03-21-2007, 06:12 PM
nynor's Avatar
oh boy...
Old 03-21-2007, 06:42 PM
YEP!!!!
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 03-21-2007, 06:48 PM
ae1969's Avatar
If the engine is still in...........
You will need......
Patience, left hand drill bit, heat .......... repeat
Worst case scenario you drill it out and re-thread. Not as bad as it first seems.
Old 03-21-2007, 07:36 PM
Burn the fire.
Brando's Avatar
EDM...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-21-2007, 07:58 PM
Greasy Member
many944s's Avatar
I had the same thing happen on a friends 951...
All I can tell you is, you need alot of patience, a drill bit, an "easy out" and a steady hand!
good luck!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 03-22-2007, 12:20 AM
thoen's Avatar
hi todd,
did you find the hatches?
i sent a pm.
thanks!!!
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 03-22-2007, 07:32 AM
Cars & Coffee Killer
legion's Avatar
I'd recommend an "easy out" over a left-handed drill bit.
An "easy out" (at least the one I have) is tapered and reverse-threaded, so it will really grab the broken stud.
5 liters of VVT fury now
-Chris
Old 03-22-2007, 07:37 AM
Send a message via AIM to hpaulb
Can you post a picture. Not quite sure if anything is sticking out. Mine was the same when I got it. Once I took the tensioner assembly off the block, there was enough to grab with a wise grip and it came right out.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 03-22-2007, 11:15 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I agree with Alex. I would start with a left handed drill bit to drill a hole in the middle of the bolt. I would file it flat first (if enough of the bolt is still there and if not use a center punch that is the same size as the hole to mark the bolt center. Then drill with a left handed bit and it may grab it enough to back it out. If not, then stick the ezout in the hole and back the bolt out. Make sure you don't break the ezout...then you are in real trouble.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-22-2007, 03:16 PM
It is broken off just a little below the surface of the block. But....it is a clean break. Going to Sears to get a left hand drill bit.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 03-22-2007, 04:26 PM
I've never seen a left hand drill bit. Why would you need one. A hole is a hole.
The most important thing I find is to get it perfectly centred and straight. I have never had any luck with easy outs. After much flustration, i find that i end up increasing the bit size till i get to the threads then fish out the little bit of remaining metle and run a tap through it.
Use lots of heat and penitrating oil. The easy out may work???
98 BMW 740i
Old 03-23-2007, 06:10 AM
thoen's Avatar
TODD
PM SENT!
Old 03-23-2007, 04:31 PM
ae1969's Avatar
The beauty of a left hand drill bit.......... it wants to pull the bolt as it drills......that and some heat. WOrks everytime..........
And if not........ it drills it out anyways.
Two possible outcomes with one procedure.....
Old 03-23-2007, 04:47 PM
Redline Racer
HondaDustR's Avatar
Oh man...I feel your pain but you've definitely got it worse. I had to drill out a stripped cam sprocket bolt, and I can assure you, I was thoroughly pissed beyond belief by the time I finally got it. Lots of patience needed is an understatement... (and lots of drill bits. Those things are too soft...untill you want to drill them out )
Is there even enough room to fit a drill in there? Maybe if you took the radiator out.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-23-2007, 04:54 PM
thoen's Avatar
PM SENT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-24-2007, 02:07 PM
