Blondie's Avatar
Update, more questions
Got it running, but of course not %110 trouble free.
The problem was timing to get it going.
However, I cant get it to idle with the airbox/AFM sensor connected. I had to hold the throttle open manually, opening it more and more every few sec. to keep it running.
But she idled fine on her own at +/- 900 rpm with nothing connected before the j-boot. (Including the airbox.) She was burning a bunch of oil....exhaust was nice and thick. (See my previous thread on oil in my intake.)
I started her up first crank a few min after the first session (again, without the airbox/AFM sensor in place,) to watch the idle, and she just died abrubtly after a solid 10 sec. or so of running. Immediately after I tried starting her up again but nothing came about. None of the cylinders fired, but I got a trickle of smoke coming through the j-boot.
I wanna say timing but...how? That belt was, dare I say, pretty darn snug. I was thinking the smoke could be the oil residue in the intake burning off after it heated up?
Questions? Comments? Answers? Thanks again guys!
'86 Porsche 944, Guards Red
Nancy is currently [going in for the final 'once over' this week..]
AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL
Old 03-26-2007, 07:51 AM
Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
I would check that AFM. Check resistance to spec. etc.....
A friend of mine had a 92 Dodge Stealth RT non turbo and his car had the same symptoms. Unpluging the AFM helped but it ran terrible. It all started because he messed with it by trying to put a cone filter on with an adapter. He thought it would be a good idea and help with flow if he removed the metal honeycomb insides that actually help the AFM read the air.
Not that you even touched it, but it seems to be the source of your problem the way you describe it.
I hope this helps.
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 03-26-2007, 08:37 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Timing is set by the computer and there really isn't a way to adjust that...providing the belts are on correctly. I agree with Gremlin...check the AFM by the specs in clarks garage.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-26-2007, 06:43 PM
