Blondie's Avatar
That was my guess also. Definately not stuck open. Its free as a bird...
'86 Porsche 944, Guards Red
Nancy is currently [going in for the final 'once over' this week..]
AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL
Old 04-02-2007, 02:18 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
What is the number on your DME?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-02-2007, 04:15 PM
Blondie's Avatar
Bosch
0 261 200 077
Made in Germany
944.618.121.04
TYP 944 MWN-01
Old 04-02-2007, 04:33 PM
Blondie's Avatar
Waiting to go get myself an AFM and DME from my parts guy.
In the mean time..
I was browsing through some various search results and I came across a thread on the aftermarket injector hats. Seems that if their not seated properly, they'll be shooting streams of fuel instead of a fine spray.
Possibly contributing to my super-rich mixture??
So I need new info!
How fine should the mist be?
How far back should I force those aftermarket hats on?
Old 04-04-2007, 04:31 PM
Makis's Avatar
I reacon the super rich mixture you are getting is caused by misfiring.
Old 04-04-2007, 04:43 PM
Blondie's Avatar
"I have rebuilt the head on my 924S and have everything back together. Now the car starts, but dies instantly. The only way the car will run is at WOT, even half or 3/4 throttle will kill the engine. I believe it is a vacuum leak."
Just like my problem.
Taken from Injector Spray
Old 04-04-2007, 05:21 PM
Politically Incorrect
onZedge's Avatar
Actually, if the fuel injectors inject a stream rather than a finely atomized spray, you will be on the lean side since streamed in fuel will not burn as completely (hence, excess air) as a finely atomized spray.
Edek
'87 924S
'91 535i
Old 04-05-2007, 11:10 AM
Blondie's Avatar
Then why are the plugs so black? All I know is that I have the same symptoms as the member in that thread I just posted a link to. I'll try mashin those hats on the injectors and see if they click into place anymore then they have. Totally sounds like the kind of solution I'd need to fix a running issue with this car lol
I should rename this thing 'irony'. lol...
Old 04-05-2007, 12:40 PM
Makis's Avatar
The plugs will be black if they are not igniting the mixture properly. This will happen both when the mixture is too rich or too lean or the ignition circuit is not up to standard. Rich mixture would normally help when cold and not cause the stalling you describe. I would double check that coolant sensor and do check if any of the two terminals of the sensor is grounded. This can be done by disconnecting the sensor lead, put one wire to the cylinder head were the sensor is bolted (ground) in and the other one the sensor terminal. Check both terminals. In both cases you should have open circuit. If not the ECU will get the wrong signal.
Alternatively if you cannot measure the sensor like that just disconnect it when the engine is cold. If the engine starts and runs OK for a few seconds without pumping the gas pedal then you know for sure it is the sensor.
Old 04-05-2007, 02:33 PM
SoCal Driver's Avatar
Grounding. Could be bad ground between the engine and the chassis and the chassis and the battery. Note this would change the engine temp reading.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-05-2007, 04:11 PM
Blondie's Avatar
Interesting..
Old 04-05-2007, 05:15 PM
When I want to know what my injectors are doing I pull them and put a clear tube on them so I can watch them as my engine turns over. If you see streams instead of a fine mist, then you know what the problem is. Hold a plug on the intake to see what color the spark is...the color tells the condition. Blue is best, yellow is worst, orange in between...if I remember that correctly. Car should run on orange or above. If it appears weak, clean grounds as SoCal suggested or look for other poor connections.
Tom
Old 04-05-2007, 07:39 PM
Blondie's Avatar
Spark is white/blue and stupid hott. I held one on my open palm just for you guys.
Ok so I didnt really but I am intensely curious as to how those injectors are doin.
Old 04-05-2007, 10:17 PM
