odometer-quick question
I have a 1984 944 and the speedometer works but the odometer does not. This is because the odometer gear is striped? any other reasons?
Porsche 1984 944 '94 Ford f250 Diesel |
winter-hater club member
the odometer gear sometimes slides down the shaft. you will need to remove the cover of the speedo and see.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
If memory serves me the odometer is driven off of the Drivers front wheel, you may need to check there too.
AJF 1998 Glacier White Boxster 1971 Fiat 124 Spyder 1999 Mercury Mountaineer |
if the speedometer is working, the cable is working.
I vote it's the plastic gear. It's almost always the issue.
nate
1988 944... and a bunch of other cars ![]() |
Pull the gauge down as here, and I just used a drop of supa-glu to fix it in place.
http://www.pelicanparts.com/techart...auge_repair.htm
Dave Jezza http://www.pelicanparts.com/gallery/jezza944 1984 944na Krystalgrun (Crystal Green) |
yup, gear slid, do as jezza says!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
eh, maybe not, mine actually had the teeth stripped off of it, if that is the case try odometergears.com
nate
did you reset it while the car was moving?
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
It came pre-busted for my convenience
![]() nate
Misunderstood User
Never ever reset the odometer while the car is moving.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
the late cars break the gears, the early ones slide. yours was broken because it is a late car, and his has most likely slid. every early odometer i've taken apart that hasn't worked - has had a gear that slid.
also, never reset the odometer while the car is moving, or a pox be upon you!
umm... the car in question is an '84. early, unless i am mistaken.
i know, my response was to toolboy
right. gotcha.
thanks for the help
mine is an 83, and it's gear is stripped...
need a gear? i have a few lying around...
oh hell yes if you've got one! (that is, if you were talking to me.. lol)
haha sure! i'll put it in the mail tomorrow.
