Removing windshield
Anyone have any advice or a good write up on how to remove a 944 windshield with an antenna without breaking the glass? Thanks.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Factory manual suggests poking a steel cable through at the bottom corner then pulling the steel cable around the windshield like a saw to cut the glass from the adhesive. Takes two or one with really long arms.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Also found that the warmer the temp the easier, maybe a heat gun can help for this. Plenty of patience, ive got some out and also have cracked some using piano wire.
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
I think I am going to order a nice little kit from eastwood. I have 4 cars that need windshields removed and it seems like a worthwhile investment. Thanks guys.
That Guy
Removed a non antenna from my friends '85. It was not as easy as i thought it was going to be. I used a kit from Harbor Freight. Basically a roll of piano wire, two handles (to hold the wire) and a poker to get the wire through the old gasket. Its defenetley a two person job. Remove the upper headliner before you start, or you will very likely rip that when you go past with the wire.
I am lucky the windshield i was removing was already broken, as it required some coaxing with my size 11's pressing on it... .
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Yes, it is very difficult to remove one without cracking one.. The wire type tool is probably the best bet .
No left turn un stoned |
Well, it takes patience but it can be done. Recently we pulled a windshield from my 83 using wire... the key is to get the right gauge and be patient. Too fast and the wires heat up and break. Too thick and you can't get it through the sealant.
life is participation in evolution 87 944 racer . PRO44 #1 01 986S endurance racer 93 968 coupe 6spd |
