annoying engine vibration
My 88 924s has had an engine vibration at two points- 1200-1400 rpm (minor) and 3000-3200 rpm (major) for several months now. The car wasn't running for a year before this and I can't remember it vibrating before that.
The balance shafts are on time for sure, and I just replaced motor mounts which smoothed out the whole rpm range, but did nothing to help the problem spots.
It happens with the clutch engaged or disengaged, and I had a friend hold his hand behind the muffler and feel for a miss, but the exhaust pulses feel quite smooth. Does anyone have an idea of what this could be? Possibly a damaged balance shaft?
Thanks for you input
-Gabe
-black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her
-1987 MR2
---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON---
Old 04-23-2007, 04:38 PM
SoCal Driver's Avatar
Your balance shaft pulleys are on wrong. It's the only thing that will cause these vibrations.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-23-2007, 07:51 PM
Redline Racer
HondaDustR's Avatar
Here's the clark's garage proceedure for checking that.
http://www.clarks-garage.com/shop-manual/eng-08.htm
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 04-23-2007, 08:34 PM
I will have to check again. Thanks as always socal.
-Gabe
-1987 MR2
Old 04-23-2007, 08:38 PM
Use a piece of wire to probe for the key in the key way. Even if the O and U are in the correct orientation the key ways can be off a half turn.
Old 04-23-2007, 11:35 PM
