S.S.D.D. (repost)
Still have that same hunting idle issue even after I replaced the bad O2 Sensor. Is it possible that if my Oil/Air Seperator O-rings are not seated correctly that it can mess up the internal engine vacuum and cause my hunting idle???
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN. 2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance. |
How about an Idle Stabilizer.
87 944 72 914 Sold 84 944 Sold 85.5 944 Sold 78 924 (first car) RIP |
thats replaced.
Heres a list of everthing replaced or I have done: IAC TPS DME Temp Sensor Throttle Body Reseal Cleaned Throttle body and intake New Vacuum lines plugs, wires cap and rotor O2 Sensor Oil/Air seperator o-rings all gaskets and seals injector seals and caps used 4 cans of carb clean and brake clean to find vacuum leaks.... ZERO found Adjusted idle by bridging pins B & C with no results used seafoam car idles fine whe first started but about 10 seconds later it hunts for an idle. Even if the engine is hot, i shut it off, wait 1 minute then restart and it idles fine for a few seconds and then acts up. According to my AF Meter it idles fine when rich. with plug B & C connected it runs rich and idles fine. With O2 Sensor UNPLUGGED it idles fine (probably running rich too) There is unmetered air somewhere I know it, but I can't find anything for the life of me. Its been weeks of searching with no end in sight. I'm ready to give up.
Anyone got any ideas on what I should check that I haven't???
If the "hats" on the fuel injectors are not seated correctly, could this block the stream of fuel and in turn cause my idle problem??? I'm really at my wits end and have done literally a hundred checks and end up back where I started. -John
Greasy Member
Are you using the factory air-box, or do you have an aftermarket cone intake? I use a K&N cone on an adapter I built and it idles fine... A buddy here in town has an aftermarket unit he bought on Ebay that also adapts to a K&N cone, but his car will "hunt" for idle with it installed. If he puts the factory air-box back on it idles fine?!?
Just an idea... -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Stock box. No holes drilled or anything like that. It does have a K&N Drop in but thats been there even before I bought it.
I do remember though when I was checking things I gave the throttle a quick open by hand to bring the revs up quick and it back fired through the intake... scared the S*** out of me. What was that all about?
Greasy Member
Of course a backfire is a give away to a timing issue... Have you tried swapping out the DME? Does it have an aftermarket chip?
No aftermarket chip.
I was thinking timing before, but was not sure because I heard that a backfire through the intake could also mean excess fuel in the engine and it can detonate easily. I quickly opened the throttle by hand and thought I gave it that chance to do that. I have yet to find a DME I can borrow and test in place of mine. I don't have $200+ to spend on a hunch.
Dog-faced pony soldier
Did you check the output voltage from the temperature sensor at the DME? Could be a cracked wire. 20-year-old wiring tends to get brittle.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Actually, a backfire is not always timing.
I have experienced a lean off idle backfire with a vacuum leak (big one while setting up the s/c). I can do it again if I try ![]() have you checked to see if the TPS is adjusted correctly, you just have to have engine off and listen for a small "click" when you crack the throttle. If it is mis adjusted it will be using the AFM signal which may be sending a very rich mixture for idle this can also cause an intake pop .
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
Holy smokes..
This couldnt be any closer to my problem! I've gone through the exact same diagnostic list, Gremlin. I've been suspecting the injector hats myself, as I recently did those. My car is running stupid rich and hunting hardcore as well. Sorry I cant be of any help my friend..but maybe togather we can figure this one out?
'86 Porsche 944, Guards Red Nancy is currently [going in for the final 'once over' this week..] AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL |
I am leaning toward the same deduction as blown944. You need to check the tps at the DME not at the tps itself. Of course you could also ohm the wires, but a broken wire or poor connection at the tps or dme would cause the same problem even if the tps switch itself is working correctly. Also ohm out all your grounds.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Thanks for all your input everyone.
To answere some of the questions: The TPS DOES click just I move it off idle. The slightest movement (about 1 degree) and it click. I did not check the TPS at the DME. I'm stupid for not trying that. I will do that at my earliest convienence. Blondie, i hope I can figure this out so we can fix this problem. It seems to be a common problem with the 944 but everyone else seems to get it by replacing simple parts. Why does mine have to be so complicated?!? ![]() Electronics were never my strong point at UTI... Again. thanks for your input it is much appreciated!
Maybe the brake booster has a leak.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
....But is it possible it could be internal? But that would also mean poor braking and my brakes are fine. ![]() -John
Next time it's surging take the large hose off of the booster and plug the end. Should be taken off of the plastic fitting that is at or sticks into the booster and not the booster diaphragm itself. Could be that plastic fitting.
Back from Beyond
Aux air valve stuck open.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
I've replaced that already. I'm going to re-seal my injectors because I did a little more research on the kits available. Looks like the caps I got from Bosh are the bigger yellow ones. The tip of the injector (or the business end) sits real far bahind the opening of the 'cap'. I ordered some that were highly recommended off of Rennbay. SoCal, I'll check the brake booster as well. Watch it be the stupidest thing too...
So theres two different injector kits? I got the one with the yellow hats as well...
Hmmmmmmm so the plot thickens... Where did you order this other injector kit from?
I actually got my other Injector Kits from ********.com ::HIDES::
