Greasy Member
many944s's Avatar
intermittant injector??
Had a unique issue the other day when moving the cars to my new garage. I started the 944, and it only ran on 3 cyl's. I checked the plugs, and I was getting spark to all 4 plugs, but when I shorted each one individually, #4 wasn't firing!
I turned the car off, and tried re-starting a couple of times, and it still was missing. About an hour later, I tried again, and it fired right up on all 4!?
Anybody had this happen before? (I checked the the #4 injector wire with a noid light, and it was indeed getting signal when it was missing) Just dirty? Am I looking at a new injector in the near future?
Whatca all think?
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 05-01-2007, 03:21 PM
Blondie's Avatar
You could pull the fuel rail and pull the electrical leads on all the injectors but #4. Put the injector into a cup and crank a few times to see how much (if any fuel) your getting from it.
'86 Porsche 944, Guards Red
Nancy is currently [going in for the final 'once over' this week..]
AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL
Old 05-01-2007, 03:26 PM
Greasy Member
many944s's Avatar
I would, but it's running fine now...
Old 05-01-2007, 03:29 PM
Blondie's Avatar
Make sure the contacts on the injector and the plug going in are sparkly clean..if they are then I'd just bet on gunk from the tank making its way up to the rail.
Old 05-01-2007, 03:33 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
It's really hard to diagnose a problem on a perfectly running car, isn't it? No way to tell now.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-01-2007, 06:11 PM
SoCal Driver's Avatar
It's not uncommon to have one of the plug wires pull out of the end of the connector. The weather boot will hold it in place. The end of wire connector (threaded to screw into the connector) can also corrode like heck inside the weather boot. Then the ballast in the connector can fail too. But this is very seldom with a stock ignition setup.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-01-2007, 07:34 PM
