Send a message via AIM to hpaulb
Key word is intermitant. Fixed 1000's of electrical equipement and nothing infuriats me more than the problem that won't show itself till your doing somthing else. Then try to imulate it!
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 05-15-2007, 06:19 AM
+1 Intermitent problem(s) can't be found without process of elimination which unfortunately requires throwing parts at the problem.Some of these parts are what I consider maintenance items as they do fail due to age.
I'm with anyone who suggested:
1) DME (Fuel Pump) Relay and related contacts
2) Ignition Switch
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 05-15-2007, 08:08 AM
Send a message via AIM to olivar
ditto.... check you reference sensors mine does the same thing once in a blue moon,either the connections are corroded or they are failing.DME would be you other choice,check connections.let me know what happens.
Old 05-15-2007, 12:44 PM
UPDATE: It finally failed for the mechanics! They are thinking probably a reference sensor or a DME. Something that regulates power to the coil. They didn't get the chance to test it when it failed because it started up by the time they got the equipment out to it. At least they know I'm not crazy. I'm pretty sure it's not the ignition switch because I can beat on it and wiggle it and it doesn't start. It always comes down to waiting. We'll see if they can't get it to fail one more time, long enough to test it. I trust these guys. There were 2 early 911's with the engines pulled out when I dropped mine off, so I no Porsche owners trust them with their cars and they have experience there. I'll keep you guys posted.
Old 05-15-2007, 03:56 PM
SoCal Driver's Avatar
The ignition switch provides power to the coil. The DME grounds the coil to fire it.
Your ignition switch "test" is bogus.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-15-2007, 03:58 PM
I'm with Bill
Rick V's Avatar
It would be interesting to see if the car is loosing the injector pulse as well as spark.
Since you made no mention to black smoke when the car does re-fire I would suspect it is.
Old 05-15-2007, 04:36 PM
Another vote for the DME (Fuel Pump) Relay. Relays usually go bad slowly because of rusty / weak contacts. It's easy enough to just put in a new relay. (If it isn't the relay, you can keep one as a spare. They do go bad.)
Old 05-15-2007, 05:06 PM
ae1969's Avatar
Send a message via ICQ to ae1969
When it fails.... tap the dme.
More than likely bad soldering point on the ignition driver....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-15-2007, 07:38 PM
Burn the fire.
Brando's Avatar
Originally posted by Pistol Pete
[...] There were 2 early 911's with the engines pulled out when I dropped mine off, so I no Porsche owners trust them with their cars and they have experience there. [...]
Motor Meister has probably 10 times as many cars with their engines pulled, people trust them -- doesn't make them trustworthy... FYI.
Glad they were finally able to replicate the problem. Now they can get to repairing it. Way I tested for bad speed/ref sensors was with an oscilliscope... Let the car run and wait for it to show irregular spikes on the graph.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-15-2007, 10:18 PM
Not a lot of people know how to correctly operate an ossiliscope. If all else fails use, there is always driving arouns with a volt meter hooked up. Black lead to ground, place the meter on your console and hook the red lead to whatever point you want to monitor. DC volt scale and watch. Positive side of coil or negative. Positive will maintain 7-12 volts constant. Ground will be 0-.4 volts and float to 7-12 if the conection is off. Same for any other point monitord.
I know a local Porsche shop with a very respected owner/mechanic. I'm in there one day waiting for Oly and watching a mechanic wack on the side of a control arm to pop out the ball joint (BMW) and low and behold, he hits the fender square. Wipes off the smudge and keeps working. You think he told his boss or the owner?
98 BMW 740i
Old 05-16-2007, 12:06 PM
Eldorado's Avatar
LOL paul, remind me never to go there!
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-16-2007, 12:24 PM
Which shop is this... come..on do tell... .
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 05-16-2007, 01:17 PM
Hopefully you figure out what it is, as there are the several possibilities that have been stated here. My car behaved like this for about 2 weeks while my reference sensor was on its way out, but luckily for me it decided to completely die one day... What color/yr/model 944 do you have? I will have to keep any eye out for you on the road
'84 944, '05 GTO
Old 05-16-2007, 04:19 PM
It's a 1987 Silver 944 N/A. Do you live in the city or the suburbs? I go to Hamline, so I'm in Midway, St. Paul.
If the ignition switch was bad, would the car die while idling and fail to start, or would the problem only occur while trying to start the car?
Old 05-16-2007, 10:01 PM
Find and read then perform the five minute test.
Old 05-16-2007, 11:08 PM
SoCal- Found it, read it, and now I'm gonna take my car back from the mechanic this weekend and see if I can't track this down. Thanks.
Old 05-17-2007, 08:55 AM
I'm assuming this is the test to which you refer:
Go through the five minute quick test.
Check for power at the coil and at the injectors with the key on.
No power at the coil it's the ignition switch or related wiring.
No power at the injectors it's the DME relay.
Power at the coil and injectors points to a bad reference sensor. The connector may be corroded and/or not plugged in all the way or cracked and may have broken the wires inside.
Check if the sensor is working by pulling a plug wire, inserting a spare plug, grounding the plug to the intake and cranking the engine. If there is spark then the reference sensor is working.
Could be the second set of contacts in the DME relay. These are for the fuel pump. The fuel pump should run for a half second after you stop cranking. Have someone listen for it behind the passengerside wheel well. Check the fuse for the pump too.
On the early 944's you can use an alligator clip jumper between Aux fuse #2 and #3 to run the fuel pump directly. Count from the drivers door. Don't leave the clip on.
Come back with your findings.
Pete
1987 944, Silver
Old 05-17-2007, 09:52 AM
Well the shop was I believe Furtmier motors? here in Bridgport. Part of Kitchener. Not the freindlyist guy either. Stopped by one day after buying a lot of parts, to ask a general question with the spun #2 bearing in my hand. Looked at me like, what do you want, pay me for the work. Last time I go in there.
98 BMW 740i
Old 05-17-2007, 12:12 PM
Part of it. Once these findings are made there are further check points. Most of the time it's the DME relay and/or the sensors.
Old 05-17-2007, 02:55 PM
Porsche Crest
Got my car back from the mechanic today. They found a burned out pin on the DME; one that would interfere with spark to the coil. I have a new pin soldered in and it didn't cost an arm and a leg. I'll hope this solves the problem, but IF it fails on me again, I'll run the test and we'll go from there. Here's to hoping...
Pete
1987 944, Silver
Old 05-22-2007, 01:57 PM
