don't know what is bad with turbo !getting crazy
I getting crazy I couldn't sleep last night thinking what can be wrong with it my car is 944turbo 1986 !I live in Small town no mechanics that know anything about 44's the only mechanic Porsche is in big city 4 hrs away and he is old he had car for 1 month coudn't find the problem! here is deal car run great but always after 30- 45 minutes of driving the weird things happen I can see is not turbo or waste-gate problem because turbo has less thn 2k and wastegate same I think is some sensor !not working 100% witch one ????for exampleafter 45 in highway going in 4 gear 65m/h you can feel car trying to die the lights in dash pop on ( brake and all lights up), you put 3 geart compression and car start and keep going good maybe good for 3 minutes and then bad again for 2 senconds and good again and just like that! you park car let it cool couple hrs and it run good again until 45 minute and bad again!!!
Someone told me change the dme temp sender !is cheap I$25.0
other told me replace coil he belives when warms up dose'nt work good! my tps is missing the cover (so you can see inside electronics)how can I test these things to make conclusion !what else could be causing that to car!!!!
1986 951 silver/black
Old 05-16-2007, 02:50 PM
Hello again.
Alina.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 05-16-2007, 05:15 PM
Re: don't know what is bad with turbo !getting crazy
You know the two 951's that you have for sale on Autotrader? Are they the same car? The price is the same and it looks like they are the same in the pictures, but I cannot tell. Thanks!
Cory
Old 05-16-2007, 09:54 PM
McFly944's Avatar
Originally posted by WolfeMacleod
Hello again.
Alina.
+1
Craig -
86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties
Past:
89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car
Old 05-16-2007, 09:59 PM
Z-man's Avatar
Keeping an eye on ketchum951 with raised brow....
Ketchum - are you Alina?
-Z
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 05-17-2007, 06:50 AM
Try running with the tps unplugged. Drive normal and stay off boost while doing so. Idle will vary, but if problems go away, then i'd replace the tps.
Old 05-17-2007, 07:00 AM
Eric 951's Avatar
put in super-lucky fast gear oil. then push clutch button. car is running turbo boost. problem for nobody ajajajajajajajajajaj!
Eric
83 911SC/83 944
bunch of Honda 750s
Old 05-17-2007, 07:08 AM
I'm sorry but I'm a man..my name is fernando!
who is alina?
ps. Can someone help me with my problem please?
Old 05-17-2007, 03:58 PM
Eric 951's Avatar
who is alina?
still seems fishy--same type of posts as alina--same (new) city as alina--ketchum/sun valley idaho
as for help--do what sox suggested in the turbo forum--or what robm suggested here, then report back the findings.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 05-18-2007, 04:31 AM
If this is real then check your grounds.
Old 05-18-2007, 05:04 AM
winter-hater club member
nynor's Avatar
s/h/it already used the famous alina phrase "so and so is nice person"... ajajajajaja!!!!
"COOL PRIUS!" - Nobody Ever
Old 05-18-2007, 06:46 AM
