O2 sensor question
for my 84 944:
I Failed Nevada emissions (horribly) CFC and Co2 levels were nearly double (especially at idle) Car is running a bit rough and idling at about 750 RPMS. First thing I'm going to do is change out the o2 sensor.. The car started life in CA and has been there (I believe) most if not all of its life. It lives in Vegas now, and I was wondering if 1) Does it have a CA o2 sensor installed (how can you tell?) 2) Can I replace it with a standard (non-CA) o2 sensor? 3) would it be (better) if I put the more expensive CA o2 sensor in? Thanks!! -9 |
Ok, a little research and I see that, since my O2 sensor has 3 wires coming off of it, it IS a CA O2 sensor (bummer).
A little more research and I see that the 2 extra wires are for heating the sensor.. So, with that said, one question still remains, do I NEED to get the CA replacement O2 sensor or can I now use the regular single wire type now that the car is in Nevada? Thanks again -9
'84 944 N/A '01 Audi TT Quattro Convertible |
If your car came with a heated sensor, then you should put a heated sensor back in. It's not a California sensor, it's how they have the computer set up to work with the sensor. Put the three wire back on there. There are some that try a generic sensor and I'm not sure how well they work as I've always used the OEM, but do a search on here and that will provide the part number of the generic part number. If you can't find it, let me know and I'll look it up. I think it was on FR Wilk's site as well.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Thanks Razorback.. I don't want to spare any expense if it will sacrifice performance. I'll get the OEM. It would have been nice if the car had the cheaper one, lord knows I have bigger fish to fry on this car and dollars will go to it one way or another. I'm hoping to make this old gal into a awesome machine again, so I'll pay whatever it takes to do it.. One part at a time..
-9
Come on guys! Co2 is what you exhale. CO is what cars (or most anything burning) emits.
And what the heck is CFC's??? Chlorinated Fluro Carbons??? Didn't know that A/C systems were tested as part of the emissions.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
ive heard of guys doing a straight swap and install with the ford 3 wire O2 sensors, they fit, all you need to do is splice the wires on... i havent tried it yet but i understand its a compatible swap. (the ford sensor i think is around 50 bucks?)
1995 993 C2 |
Ok socal, I get the point.. I made a mistake in phraseology. Thanks for correcting me, I'll never do it again.. I think everyone understood the problem. I'm glad you got to flex your superhuman automotive knowlege and make me look stupid..
I'm not a professional mechanic and never claimed to be. Just an amateur hobbyist who enjoys porsches. EMB Pilot, who you work for? Me, Allegiant Air... Former Allegheny, Shuttle America, Mesa (in that order) furlough fodder... Just upgraded on the -80 at AAY..
Pm sent
welcome to the board nine, let us know what you end up doing.
1995 993 C2 |
This is one at a cheap cheap price and worked perfect.
I had a nasty smog test, changed the o2 sensor with the one linked above and passed with flying colors. Nearly cut all my numbers in half.
Craig - 86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties Past: 89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car |
You are not the only one that is confusing a single molecule of oxygen with two molecules. The difference in the Latin di for two and mon for one. Better get past your thin skin when confronted with misunderstandings. These are hobbiest cars as few who own them have the income to take them to a P-car mechanic and do most of their own wrenching.
As to your "CFC" statement; most likely HC's or hydrocarbons. This is the unburnt fuel coming out the tail pipe. The catalytic converter is supposed to catch most of the HC's and CO's and NO (also NOx - nitric oxides or nitrogen with an oxygen molecule or "rusted" nitrogen) before they reach the end of the tailpipe. http://en.wikipedia.org/wiki/Nitrogen_oxide http://en.wikipedia.org/wiki/Catalytic_converter Back to CO and CO2: Yes there is CO2 that comes out of the tailpipe. BUT! Until recently it's not been considered in the testing regime for automobiles. Thank you ALGORE. Now we can also have a discussion on down wind turns.
I put in a generic bosch. I don't recall which model, I found the info on the 'other' forum I believe.
If you need me to dig through my records to find the model, I can. Just let me know.
'84 944 Black/Black _______________ '04 GTO Black/Red - stock '92 Maxima SE - Is it wrong when your Maxima has KONI Reds and your 944 doesn't? ![]() '94 Maxima GXE - winter wheels. |
winter-hater club member
do a search in the turbo 944 section here. the exact part number is listed for a ford 3 wire. i used one, it works great.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
CO and HC levels.. Got it.. I left the failed emmissions print out in the car and attempted to post from memory.. I didn't give it much thought obviously before I hit the send button.
Gives the rest of us ideas as to which way your emissions have shifted. Sometimes just an O2 sensor does the job. Sometimes it's the AFS, or temp sensor, or just a vacuum leak.
NyNor , it looks like the one you used matches the one i just put in my explorer. u just cut the wires and crimped them? quick job?
1995 993 C2 |
yeah, piece of cake. took 15 minutes, tops.
Pulled the old one off today and the wires were brittle and cracked all the way to the connector.. Rather than screw with splicing the wires to the universal, I decided to just replace the whole damn thing with the OEM Bosch 13001. Did some shopping and found it cheapest (129.00) at Partstrain.com.
ouch
if you're going to do that every time you buy parts - you're going to be bending over a whole lot.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
