armandodiaz's Avatar
another manual rack conversion
This is going on an 87. But there's one answer I can't find. I would like to keep my late off-set wheels (I just picked up 2 sets). So, can I just install the manual rack and shaft, and use the old tierods and control arm?
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 06-12-2007, 08:24 AM
TNT25169's Avatar
Send a message via AIM to TNT25169
From what I have read that is correct but I think you also need an early steering shaft because it's longer than the later/power steering ones. Let me know how it goes because I'm considering it as well.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 06-12-2007, 08:58 AM
You will need new tie rods. The tie rods for the power steering rack will not fit a manual rack. There are tie rods available for a manual rack and late offset cars, but they are expensive. You can keep your control arms.
Old 06-12-2007, 09:01 AM
Yes the Intermediate shaft needs replacing. In looking at PET there is a listing for a manual rack under 87 944. It has the part numbers:
944.347.033.03 for the complete tierod
171.419.831C Boot
171.419.832C Boot
This should let you keep the alum control arms and late off-set wheels.
Hopefully someone can verify.
Armando Diaz
Old 06-12-2007, 09:02 AM
TNT25169's Avatar
Let me know where you find late manual tie rods if you do.
www.apartabove.com
Old 06-12-2007, 09:04 AM
Paragon sells the late manual tie rods for $145 each.
Jason
88 924S SE
Old 06-12-2007, 09:39 AM
