Lexluther's Avatar
Send a message via ICQ to Lexluther
1987 944 compression specs
Hey I picked up a 87 944, it needs the usual water pump replaced, I ran a compression test and was curious what the cylinders should be in PSI?.. I can seem to find this info anywhere. It is stock. Non turbo. Thanks
Old 06-16-2007, 02:49 PM
winter-hater club member
nynor's Avatar
130ish, i *think*. more importantly, the cylinders should have similar compression.
"COOL PRIUS!" - Nobody Ever
Old 06-16-2007, 03:09 PM
Lexluther's Avatar
All my cylinders are 180 psi, I guess this is good, I wasnt sure.
1987 Porsche 944
1971 Porsche 911E..(It went home,Germany!)
1969 Porsche 912
1964 Porsche 356c..(roller)
1988 Porsche 924S (PARTS CAR)
Old 06-16-2007, 03:13 PM
nynor's Avatar
all right then. although that seems high to me.
Old 06-16-2007, 03:20 PM
Lexluther's Avatar
Better to be high than low I would think. Thanks
Old 06-16-2007, 03:25 PM
Send a message via AIM to Icey1174
Compression = (Compression Ratio minus one) to the 1.1 to 1.2 power multiplied by Atmospheric Pressure
http://www.type2.com/library/engineg/comrat.htm
That formula doesn't make a lot of sense to me with their chart with a range. Anyway...
6.5:1 is 96 -114
7.0:1 is 106 -126
7.5:1 is 115 - 139
8.0:1 is 125 - 152
That chart only goes to 8.0 and the CR for the 87 944 n/a is 9.5:1. I would guess 180 PSI to be real close to right on, if not right on, based on this info. Sounds like you should be good. And as it was already pointed out, all cylinders are close, so that is good.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 06-16-2007, 03:44 PM
Lexluther's Avatar
When I bought the car, the guy gave me a cd manual, it seems good, looks old school, anyway It says it should have 145psi and up, found that just a few minutes ago. I also found out the water pump is locked up solid!, timing belt has some slack in it too.... oh boy the fun is about to begin.
Old 06-16-2007, 04:34 PM
Yes, the fun is about to start. Is this your first 944?
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-16-2007, 04:41 PM
Lexluther's Avatar
Yes! But I have had some history with an older 911 and a 912, I mechanic on BMW's usually, this defniately looks harder. Any advice?
Old 06-16-2007, 04:44 PM
I have an 87, I think they are REAL easy to work on. I see you have 88 posts, where they about this car or another car? www.clarks-garage.com. Go there, TONS of detailed info. I have a copy of the Porsche manual and the PET if you need it also.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-16-2007, 04:48 PM
Lexluther's Avatar
They were probably about the 911e I had and bailed on... some were probably BMW posts also.. I work on alot of them also. I will check out the link, the manual I have is printed in germany, it acutally has alot of pictures! this helps.
1987 Porsche 944
1969 Porsche 912
Old 06-16-2007, 04:51 PM
PM me your email address and I'll send over the copies. They are a larger file size. LOTS of info!
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-16-2007, 04:53 PM
KY944S's Avatar
Hey LEX, Where in Ky are you?
1987, 944S (168,000 miles)..sold
1986, 944na.
My job is a hobby. My 944's are work.
Old 06-16-2007, 05:38 PM
Lexluther's Avatar
I am in Pine Knot, KY. Its roughly 100 miles south of lexington. About as far south as you can go and still be in ky.
Old 06-16-2007, 05:41 PM
I'm with Bill
Rick V's Avatar
Mine as well, the CR for an 87 S is 10.9-1
Old 06-17-2007, 11:31 AM
