Boosted Compression
I was just curiouse what alot of you boosed guys are running as far as dynamic compression ratio. Also what type of chage cooling are you using for your set up? Intercoolers, meth/water injection, etc?
This is a calculator to calculate the dynamic compression http://www.wallaceracing.com/dynamic-cr.php Any here is a link to the stock camshaft profile of the 951 and 944's, some info from it is needed for the calculation. http://members.rennlist.com/951_racerx/ (go to camshaft diagrams) Thanks for your help!
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
anyone?
Cars & Coffee Killer
I'm completely stock in that department.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
using this formula at 5800 ft and at 12psi
I'm at 13.37:1 specs as follows bore3.94 stroke 3.11 rod length 5.90 9.7:1 factory compression 12psi boost intake closing @49 Deg However the air generally measures to 7500 ft and higher so it comes out to 12.77 At sea level it comes out to 15.49 I ran some fantasy numbers @ 25 psi on 9.7 @ 7500 and it comes up to 18.99. for this some custom pistons and other mods will be necessary I'm sure. ![]() What I will probably do is to run some turbo pistons when I go the high boost route It appears tat to get the same erformance I am getting at sealevel 8 psi would work. There are o many other variables as to how an engine will handle the pressure thoughie: fuel, timing... condition,etc thanks for the links
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 Last edited by blown 944; 06-25-2007 at 08:24 AM.. |
http://www.turbofast.com.au/tfcalc.html There is another fun calculator, it's for turbos, but i'd say you could plug in the right SC numbers and get a pretty accurate estimate on HP. Looking at your dynamic compression at sea level I think with your current set up you might experience some detonation LOL.
By the way, length on our rods are 5.906" according to rods available from Lindsey Racing.
Legion, I calculated your dynamic boosted compression ratio for 500ft and it's 12.64 :1 thought you might want to know. This is assuming 12psi of boost, which I think is the max that a 951 sees in stock trim.
Just comparing numbers Sid, looks like you are almost dead on with the upper end range of the 951, however with more bottom end naturally due to the SC. At least with the 7500ft calculation. Either how, that's nice to know.
Does anyone have any clue what kind of max dynamic boosted compression you can run provide you have control over timing etc. WITHOUT detonation?
Mine said 16.16:1
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
Holy Crap!!
