Send a message via AIM to bholmes
Boosted Compression
I was just curiouse what alot of you boosed guys are running as far as dynamic compression ratio. Also what type of chage cooling are you using for your set up? Intercoolers, meth/water injection, etc?
This is a calculator to calculate the dynamic compression
http://www.wallaceracing.com/dynamic-cr.php
Any here is a link to the stock camshaft profile of the 951 and 944's, some info from it is needed for the calculation.
http://members.rennlist.com/951_racerx/ (go to camshaft diagrams)
Thanks for your help!
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 06-21-2007, 07:38 PM
anyone?
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-24-2007, 11:55 PM
Cars & Coffee Killer
legion's Avatar
I'm completely stock in that department.
5 liters of VVT fury now
-Chris
Old 06-25-2007, 04:55 AM
using this formula at 5800 ft and at 12psi
I'm at 13.37:1
specs as follows
bore3.94
stroke 3.11
rod length 5.90
9.7:1 factory compression
12psi boost
intake closing @49 Deg
However the air generally measures to 7500 ft and higher so it comes out to 12.77
At sea level it comes out to 15.49
I ran some fantasy numbers @ 25 psi on 9.7 @ 7500 and it comes up to 18.99. for this some custom pistons and other mods will be necessary I'm sure.
What I will probably do is to run some turbo pistons when I go the high boost route
It appears tat to get the same erformance I am getting at sealevel 8 psi would work.
There are o many other variables as to how an engine will handle the pressure thoughie: fuel, timing... condition,etc
thanks for the links
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 06-25-2007, 07:17 AM
http://www.turbofast.com.au/tfcalc.html There is another fun calculator, it's for turbos, but i'd say you could plug in the right SC numbers and get a pretty accurate estimate on HP. Looking at your dynamic compression at sea level I think with your current set up you might experience some detonation LOL.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-25-2007, 07:25 PM
By the way, length on our rods are 5.906" according to rods available from Lindsey Racing.
Legion, I calculated your dynamic boosted compression ratio for 500ft and it's 12.64 :1 thought you might want to know. This is assuming 12psi of boost, which I think is the max that a 951 sees in stock trim.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-26-2007, 12:55 PM
Just comparing numbers Sid, looks like you are almost dead on with the upper end range of the 951, however with more bottom end naturally due to the SC. At least with the 7500ft calculation. Either how, that's nice to know.
Does anyone have any clue what kind of max dynamic boosted compression you can run provide you have control over timing etc. WITHOUT detonation?
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-26-2007, 12:58 PM
legion's Avatar
Thanks!
-Chris
Old 06-26-2007, 06:18 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Mine said 16.16:1
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-26-2007, 07:13 PM
Holy Crap!!
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-27-2007, 06:04 PM
