I hate to ask, but.
This last weekend I put a 951 head on and torqued it using the 15-90-90 method using a widefire head gasket.
My dilemna is that the second 90 degree torque seemed more difficult than normal and when I checked the actual torque it was around 100 ft. lbs. Has anyone else experienced this and also has anyone ever checked when there end torque was using this method?
Old 06-26-2007, 05:55 PM
ae1969's Avatar
Send a message via ICQ to ae1969
When I checked my 15-90-90 .......the end torque was close to 70-75 ft/lbs.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-26-2007, 06:40 PM
Re: I hate to ask, but.
Just curious, what is the 15-90-90 method? I've never heard that before.
Old 06-27-2007, 08:51 AM
winter-hater club member
nynor's Avatar
initial torque of head nuts to 15 lbs. subsequent torquing is tightening the nuts 90 degrees.
"COOL PRIUS!" - Nobody Ever
Old 06-27-2007, 01:31 PM
Eldorado's Avatar
but as you torque the bolts, doesn't that change the torque value of the adjacent bolts?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-27-2007, 05:22 PM
Send a message via AIM to deekay911 Send a message via Skype™ to deekay911
exactly, thats why you can torque to 90, and then go round and torque to 90 again..
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 06-27-2007, 05:32 PM
nynor's Avatar
don't ask me... just going by the updated WSM. that is how i did it on my 83 with stock studs. seemed to have even torque, as i did use a torque wrench. on my turbo with race tech (or raceware, i can't remember for sure) studs, i did normal stages with a final torque of 75 lbs.
legoland951's Avatar
This is the reason why I trust my snap on torque-o-meter more than the 15/90/90 method and I have never had problems with the 50 or so 944 heads I have replaced in the past. The torque difference between individual studs can be as much as 30 ft lb with that method. Use some anti seize on the studs and clean the threads well before you torque the head down. I normally take a break between each tightening of torque and let some time pass before I clamp the head down.
There is no mechanical task so great that brute force and ignorance cannot overcome
Old 06-27-2007, 11:55 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
WTH is a Snap on torque o meter?
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 06-28-2007, 02:51 AM
sounds like a $300 Torque wrench :-)
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 06-28-2007, 04:51 AM
924Sman's Avatar
The fact the last to torques are done by degree at 90 is one good reason for unequal readings in Ft.Lbs.....Meaning who is to say the wrench was actually turned a full 90, maybe 85 or 94. Unless there is a protractor or what not I find it hard to get a pure 90 degrees from 15 ft.lbs. accurately. Also let the fasteners rest for 15-20 minutes between tightening to allow for stretching and compression of the new head gasket material and fasteners.
Dal
Old 06-28-2007, 05:04 AM
Sorry... the torque-o-meter torque wrench is a "dial indicator" type of wrench where you can see the torque reading as you apply torque and not the "clicker" type. They are said to be much more accurate and are recommended by some aftermarket bolt/stud manufacturers so I bought one a few years back. Head torque is probably where a good torque wrench is needed along with the mains/rod caps so it pays to be careful.
Old 06-28-2007, 10:13 AM
924Sman's Avatar
I see. Thanks
Dal
Old 06-28-2007, 10:22 AM
