1982911sc's Avatar
o2 Sensor quick question..
As you will see in some of the other threads on the forum I am having some bad engine hesitation problems on full throttle...After reading through hundreds of posts I am thinking it my be the o2 sensor. Is there an easy way to disconnect the sensor without have to jack up the car and wrench the sensor head from the exhaust? Can i just unclip the wires in the engine bay and drive around for a few to diagnose? Thanks!
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 06-25-2007, 09:51 AM
meister member
speedracing944's Avatar
You can disconnect it from the quick disconnect located at the top center of the firewall. I don't have a pic of where it is cause I am school right now.
You can get a Bosch single wire universal from a auto parts store for ~$20 which you crimp on the old wire.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-25-2007, 12:52 PM
Politically Incorrect
onZedge's Avatar
Which car? What year (please add to your sig line). You may have a three wire O2 sensor.
Edek
'87 924S
'91 535i
Old 06-25-2007, 03:29 PM
1982911sc's Avatar
I am sorry, I have an 86 951.
944 TURBO!!!!
PCA Member
Old 06-25-2007, 04:05 PM
onZedge's Avatar
You have a three-wire sensor. You can use Bosch p/n 13953 which is for a Ford 2.5L motor. It's cheaper than the $135 universal type - about $35-45 if you look. Just clip off the Ford connector and splice it into the old O2 sensors' harness. If the sensor is fairly new (less than 60K miles), try checking the resistance between the sensor body and the negative battery cable. Should be very close to zero ohms. I had to add a separate ground wire to the exhaust collector because I had about 6 ohms, probably due to corrosion in a 20 year old car! I wasn't about to open up a can of worms taking the whole exhaust system apart just to "clean things up".
Edek
'87 924S
'91 535i
Old 06-25-2007, 05:10 PM
Speedy
The 86 has a 3-wire O2 sensor.
Got one from Autozone for $54 (Bosch 15725) connectors supplied.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-25-2007, 05:12 PM
1982911sc's Avatar
thanks all, this car is new to me and in order to test if the o2 sensor is the culprit can I just unplug it up top in the engine bay? I am not sure which plug it is? Anyone have any pics or a good description, havent been able to find a pic on the site. Thanks!
944 TURBO!!!!
PCA Member
Old 06-25-2007, 06:06 PM
1982911sc's Avatar
OK, I think I may have found the plug up in the engine compartment, is it the top dead center of the firewall right in the middle of where the windsheild is? Or is it the near the battery box sitting out in the front of the battery box kind of elevated...these are the only two round plugs I can find? Any help would be appreciated?
944 TURBO!!!!
PCA Member
Old 06-26-2007, 10:39 AM
winter-hater club member
nynor's Avatar
it looks similar to a coax plug, dead center at top of fire-wall.
"COOL PRIUS!" - Nobody Ever
Old 06-26-2007, 02:20 PM
1982911sc's Avatar
Thanks nynor, I got it...ended up not being the culprit. The quest continues to figure this one out.
944 TURBO!!!!
PCA Member
Old 06-26-2007, 07:38 PM
This is what mine looks like in my '88. It's a three wire version. By the way, when I ordered a new one from Pelican, I ordered the "CA cars only version" and that was not the one in my car (which was born & raised in CA). I asked the Porsche dealership about this and they told me that different ones were used depending on supply...
Of the two plugs in the photo, it's the one towards the rear of the car.
Old 07-02-2007, 11:07 AM
