No Oil Pressure
I've re-sealed the oil pump and cooler on my 1984 944 (had a leak). When I started the engine-no oil pressure! I tried to prime the oil pump by putting oil in the center hole of the filter mount which didn't work. I'm wondering if the relief valve might be jammed. If it were, would there be oil in the filter? (there isn't) I'm afraid to start again without pressure-so now will only use the starter to crank to detect pressure. I'm sure the pump is good and I've done this proceedure before, so the crank bolt torque etc. is good. What's up with this?
Old 06-25-2007, 03:42 PM
You probably just lost the prime.
Use a blowgun with a rubber tip to force air into the dipstick tube and, thus, oil into the pump while rotating the engine with the starter. You could also remove the oil filter to see if it is pumping oil there.
Good luck, George Beuselinck
Old 06-25-2007, 03:55 PM
Send a message via AIM to Icey1174
Did you use the alignment tool for the relief valve? This seems to be a common problem lately.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 06-25-2007, 04:02 PM
