legoland951's Avatar
Generally when the engine backfires through the intake, its due to either wrong cam timing or ignition wire firing order. I have not seen any vacuum leak cause a backfire through the intake but have seen vacuum leaks as a result of a backfire. Since the car was running properly before, I would assume the firing order is proper and there were no major vacuum leaks. Do a quick compression test since its easy and won't take much time.
There is no mechanical task so great that brute force and ignorance cannot overcome
Old 06-27-2007, 11:21 PM
Back from Beyond
You probably know this, but not only do you have vac lines off the J-boot, you have them off the intake manifold/log as well. Have you checked those? And a backfire would have to pass throught the throttle to get to the J-boot, so check the throttle body and TPS as well.
If you were doing the cam gasket, maybe there's a lifter issue. But it seems unlikely given the car was running well a couple of days before this.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-28-2007, 09:09 AM
meister member
speedracing944's Avatar
I pulled the J-boot and all is well with it. I checked ALL the vacuum lines even the ones under the intake manifold, brake booster. I did not see any which were off or loose.
I want to get this thing running for the weekend
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-28-2007, 03:39 PM
meister member
I measured the fuel pressure at the rail. It was about 36-38 psi. (I used a guage which went up to 160 psi)
I reassembled everything and tried starting the car. This time the wind was blowing from the back of the car so I can smell a strong gas smell from the exhaust. If I nurse the car by blipping the throttle and get the RPMs above 3000 RPMs and blip the throttle the motor revs quickly and nicely. If the RPMs fall below about 3000 RPM and I blip the throttle the motor will spit and sputter.
I am thinking it is time to remove, dissasemble and test the AFM. I am thinking the signal is pegged which is making the DME think I have a crap load of air flowing into the engine when in fact there is not. In my mind this would explain the spit and sputter at below 3000 rpm and more crisp response at higher RPMs.
So far everything else has checked out. I have not done a compression test yet though.
What else is there??????
Speedy
Old 06-28-2007, 06:52 PM
I would still check the compression before moving forward. As for the AFM, do you know how to adjust the main air/fuel mixture under the rectangular plastic cover of the AFM? That would eliminate the problem of the car running rich due to AFM calibration. I have an exhaust gas analyzer (non-dyno smog machine) but I doubt most people have that sitting in their garage for this kind of problem. Your best bet is to drive it to a smog repair place to calibrate your AFM if that is indeed the problem.
Old 06-29-2007, 02:50 AM
Politically Incorrect
onZedge's Avatar
legoland951: are you referring to the calibration spring tension? IMHO there is no way a backfire would screw that up unless the fastener came out. Yes, I think speedy has an AFM problem. My AFM barn door rubbed ever so slightly when I bench tested it, but once it got hot and on a very hot day, it stuck wide open. I fixed it with emery cloth. No problems since. I also "re-tracked" the sensor wiper per FRWilk's procedure. Clarke's Garage procedure is essentially the same:
http://www.clarks-garage.com/shop-manual/elect-22.htm
Edek
'87 924S
'91 535i
Old 06-29-2007, 10:20 AM
did you check seals on the oil seperator? they shrink and break with time. pull off the large vaccum line thats connected to the j-boot right before the TB. blow into it and if theres no pressure building up then either one of the two seals is bad.
85 (early) 944
78 sc targa
"The fool who wades in doubt will float like concrete"
Old 06-29-2007, 11:16 AM
I Hate Birds
DanAllen944's Avatar
I just had the same exact problem as yours a couple weeks ago. It was the vaccume line going from the Idle control valve to the intake. I had to remove the intake to see the crack in the hose. I checked it many times with it on and i thoungt nothing was wrong, untill I removed the intake. You may want to pull the intake and throughly go throungh all the hoses.
"America is all about speed. Hot, nasty, badass speed."
Old 06-29-2007, 02:13 PM
OnZedge, I don't think its the AFM at all causing the backfire but if its dumping fuel out the exhaust and the car is running rich, it most likely will be the AFM calibration.
Old 06-29-2007, 11:37 PM
meister member
I pulled the AFM, removed the black cover over the electronics and tested the signal per clarks-garage and it checks out. There are no spikes or abnormal fluctuations in the voltage signal.
I will have to check the compression and the vacuum lines once again. i will blow in the ones suggested as well.
Speedy
Grrrr.
Old 06-30-2007, 09:38 AM
meister member
I just blew in the line closest to the TB and there is no pressure build up, I can hear a hisssss sound as I blow. I tried to smoke a cigar and blow the smoke into the hose to see where smoke came out. I could not see anything. I tried an incents stick as well but there is too much wind. I am going to try soaking the area with soapy water and see if I can make bubbles when I blow through the hose.
Speedy
Old 06-30-2007, 10:48 AM
meister member
I was able to make bubbles. On the T-connection which goes in the hole right before the TB there is a large vacuum hose. Thsi vacumm hose runs under the intake manifold and runs to a black plastic canister. The canister is located under the intake manifold between the rear intake runner and the intake runner directly in front of it. The canister looks as if it is a part of the oil fill tube. The canister looks like it goes into the engine block. It is where it enters the engine block where the leak is.
Does anybody know what this is and what it does?
How does it seal into the engine block?
Speedy
Old 06-30-2007, 11:08 AM
meister member
This is a pic of the canister where the large hose goes to.
Here is a pic where the canister is leaking. It is where the black plastic goes into the engine block right under where the head bolts on.
Speedy
Old 06-30-2007, 12:04 PM
You have 2 separate problems it seems. Backfiring and fuel dumping. If you have a vacuum leak, you should have a lean condition, not rich. The AFM can work perfectly and be out of adjustment at the same time causing the car to run rich so the testing you did cannot determine whether your car is running rich or not. Also, vacuum leaks cannot cause backfiring.
If you do a compression test, you can probable find out whether or not that is the problem causing backfiring
If you get to a smog station or know someone who knows how to calibrate the AFM, you can solve the problem of your car running rich.
If you do not do the most obvious things first, you may end up wasting time.
Old 06-30-2007, 12:11 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Pics way too big. Anyway that is the hose from the idle stabilization valve to the oil separator canister.
944.107.187.01
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 06-30-2007, 12:20 PM
meister member
Compression numbers are as follows....
Front cylinder 165
2nd from front 165
3rd from front 165
rear cyclinder 163
Speedy
Old 06-30-2007, 01:23 PM
Another thing to check is the installation of the distributor cap. There is a slot and only goes in one way. If its installed at an angle, the rotor can hit the cap causing backfire and subsequent problems. I think the compression numbers provide conclusive evidence the cam timing was never off. Are you sure the exhaust smell rich? If you check the cap/rotor and it looks ok, I can take you through the procedures of how to adjust your AFM calibration.
Old 07-01-2007, 01:07 AM
meister member
I pulled the cap and rotor off for the third time and checked continuity between the coil wire and the button on the inside of the cap. OK. I pulled the wires off the cap and checked voltage with the ignition key on and I got 12V.
I pulled the large vacuum line off of the J-boot (the oil seperator line) and put tape over the hole on the J-boot to block any potential vacuum leak and started the car. There was no improvement in the car sputtering.
Upon initially starting the car without my foot on the gas the starter engages and when it fires up it revs to about 2000 RPM and then stumbles and dies all withing about a second. I wonder if the throttle position sensor is goofy.
I will see if there is a clarks-garage write up on trouble shooting the TPS.
Speedy
Old 07-01-2007, 08:50 AM
meister member
The TPS operation checks out as being OK.
Speedy
Old 07-01-2007, 09:31 AM
924Sman's Avatar
TPS...By hand...move the throttle cam until you hear a "click", this click should be heard almost instantly. If you turn the cam more than an inch or better it needs adjusting or replaced but set the adjustment first.
You mentioned the hoses were cracked, most likely more are cracked so check every rubber line you can find. Double check the throttle body vacuum lines, they could be switched around. These are the 2- 3mm lines usually connected to a smaller hard plastic line(stock OE).
Dal
Old 07-01-2007, 11:20 AM
